Grease zerts
/ Grease zerts #1
duckruck
Paradise, Texas
kioti dk55
How to replace zerts on dk55. My zerts are pressed in and recessed. Hard to get at, I would like to replace with standard screw in zerts. I realize they would have to be drilled and tapped with 3/8 in pipe thread. Can't get the old ones removed. Recommendations please, thanks.
/ Grease zerts #2
Normal threaded zerks are either 1/4-28 or 1/8-27 pipe.
/ Grease zerts #3
"ZERTS" ?????
/ Grease zerts #4
who knew?
/ Grease zerts #6
I eat a whole lot of navy beans and other very fiberus foods. I zert into the wind with skill & ease.
Anyhow - remove the press in zert. I have a flat bar. Very thin & sharp at the very leading edge. Also very large deep "V" for engaging & pulling items. Put it under the edge of the zert and pry gently from many angles.
/ Grease zerts #9
Many people use a vise-grips with a slide hammer attached to pull pressed in zerks. You could modify the grip end so it fits into the recess and grind a pocket for the zerk.
/ Grease zerts #11
Hey - duckruck - what are friends for?? I think I might join..........:laughing::dance1:
/ Grease zerts #12
Well best I can remember the Kioti uses British thread. It was a new discovery for me months ago.
Also Amazon has a grease zerk thread checker as well. This for the British standard fittings.
British and German Threaded Grease Fittings
https://www.amazon.com/LockNLube-Gr...coding=UTF8&psc=1&refRID=ZRQGZK62YJJCXMYVY548
for verifying the threads.
Hopefully you're not as OCD as I, but would rather have the correct replacement then tap a new thread size in and then have a mishmash of fittings installed.
/ Grease zerts #14
Yeah, I'm sorry. But the confluence of finding a Persian word for fart and the given example of "zert in the wind" was too much for my adolescent brain. I mean I'm laughing really hard right now. So hard I just zerted.
/ Grease zerts #15
Oh..oo..ooo, sounds like it might REALLY hurt...... removing that zert!
/ Grease zerts #18
Leaky Zerts are a pain ....... :)
2007 Freightliner B2 School Bus (A61573)
2007 Freightliner...
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
Kubota KX080-5 Midi Excavator w/ Hydraulic Thumb (A64047)
Kubota KX080-5...
2014 CM TRAILERS ENCOLSED CARGO TRAILER (A63569)
2014 CM TRAILERS...
2019 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2019 Chevrolet...
Great Plains UT5052 Vertical Tillage Tool (A63116)
Great Plains...
