Grease zerk
/ Grease zerk #1
lakngulf
Lake Martin Alabama
Kioti CK30
Well i tried a search but no luck. What is the thread size on County Line rotary mower pto universal joint? I bought combo box from tractor supply but non fit
Thanks for your help
/ Grease zerk #2
Did you but inch sizes or metric? Probably is metric. They can be tricky to get in because the threads get mangled easily. They make tools to clean threads also.
/ Grease zerk #4
My Everything Attachments plow was missing the grease fitting in the coulter when I bought it. I wasn't sure of size, so I got something close, in a self tapping. In fact, I didn't see any threads in the bore, so I guessed they used self tappers at the plant. Kinda ironic to tap something after final assembly that could introduce debris into a greased interface, but if it's a matter of it being very close but maybe you boogered up the threads, that could work for you.
/ Grease zerk #5
some small diameter zerks are press fit. they look like threads, but are ridges that compress when installed to hold tight. there would be no threads in the hole
/ Grease zerk
I am thinking you may be on to something there. Except that the other end of the PTO does have a zerk that fits the missing spot. I plan to take it to NAPA and see if I can find a duplicate.
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
(1) Texas Built 25' Stand Alone Livestock Panel W/ Swing Gate (A66408)
(1) Texas Built...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
2011 CATERPILLAR 304D (A65643)
2011 CATERPILLAR...
John Deere Tractor Step (A65640)
John Deere Tractor...
