Grease zerk
/ Grease zerk #1
lakngulf
Lake Martin Alabama
Kioti CK30
Well i tried a search but no luck. What is the thread size on County Line rotary mower pto universal joint? I bought combo box from tractor supply but non fit
Thanks for your help
/ Grease zerk #2
Did you but inch sizes or metric? Probably is metric. They can be tricky to get in because the threads get mangled easily. They make tools to clean threads also.
/ Grease zerk #4
My Everything Attachments plow was missing the grease fitting in the coulter when I bought it. I wasn't sure of size, so I got something close, in a self tapping. In fact, I didn't see any threads in the bore, so I guessed they used self tappers at the plant. Kinda ironic to tap something after final assembly that could introduce debris into a greased interface, but if it's a matter of it being very close but maybe you boogered up the threads, that could work for you.
/ Grease zerk #5
some small diameter zerks are press fit. they look like threads, but are ridges that compress when installed to hold tight. there would be no threads in the hole
/ Grease zerk
I am thinking you may be on to something there. Except that the other end of the PTO does have a zerk that fits the missing spot. I plan to take it to NAPA and see if I can find a duplicate.
2015 FREIGHTLINER M2 6X4 T/A  24FT FLATBED TRUCK (A59914)
2015 FREIGHTLINER...
New/Unused Wolverine 72in Quick Attach Smooth Bucket (A65583)
New/Unused...
Buckhorn Poly Feed Box (A66408)
Buckhorn Poly Feed...
INSPECTION (A65583)
INSPECTION (A65583)
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
40' One-Trip Shipping Container (A66285)
40' One-Trip...
