Grease zerk
/ Grease zerk #1
lakngulf
Veteran Member
Lake Martin Alabama
Kioti CK30
Well i tried a search but no luck. What is the thread size on County Line rotary mower pto universal joint? I bought combo box from tractor supply but non fit
Thanks for your help
/ Grease zerk #2
Did you but inch sizes or metric? Probably is metric. They can be tricky to get in because the threads get mangled easily. They make tools to clean threads also.
/ Grease zerk #4
My Everything Attachments plow was missing the grease fitting in the coulter when I bought it. I wasn't sure of size, so I got something close, in a self tapping. In fact, I didn't see any threads in the bore, so I guessed they used self tappers at the plant. Kinda ironic to tap something after final assembly that could introduce debris into a greased interface, but if it's a matter of it being very close but maybe you boogered up the threads, that could work for you.
/ Grease zerk #5
some small diameter zerks are press fit. they look like threads, but are ridges that compress when installed to hold tight. there would be no threads in the hole
/ Grease zerk
I am thinking you may be on to something there. Except that the other end of the PTO does have a zerk that fits the missing spot. I plan to take it to NAPA and see if I can find a duplicate.
2015 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2015 INTERNATIONAL...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
1985 Ford F-250 Pickup Truck (A62613)
1985 Ford F-250...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
