Grease on 3PH pins, good or bad idea?
   / Grease on 3PH pins, good or bad idea? #31
I have used anti-seize and sometimes tri-flo spray the aid hook-ups. Grease just makes a mess. I guess if ya cover everything over with the stuff it would keep the dirt out but really what's the point? In my 40+ years around the stuff I've never seen a 3 point ball or pin wear out.
   / Grease on 3PH pins, good or bad idea? #32
Wear out no, but stick yes. took a couple of hours heating and beating to get one out once....
   / Grease on 3PH pins, good or bad idea? #33
It's not the wear but for ease of hookup in my experience. Things just slide together so well and the spring pins just pop right in to place.
   / Grease on 3PH pins, good or bad idea? #34
WD-40 the pins on the implement, that's about it. I always keep a can in all my tractors.
   / Grease on 3PH pins, good or bad idea? #35
Reese (the hitch manufacturer) sells oil to lube the ball. Looks like a light machine oil.
   / Grease on 3PH pins, good or bad idea? #36
Well guess I'll chime in with; used motor oil. Dad always had an old pump oil can full of used oil and used it on all the pins, balls, and sickle bar. Every five trips around the field when cutting reauired a stop to lube, of course these laps stretched out as you moved towards the middle of the field. That oil can is still on the old tractor, but I don't put anything on the new stuff unless it is rusty then I will give it a squirt of the oil when I hook it up.
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2018 Terex RL4 4000W Towable Light Tower (A49461)
2018 Terex RL4...
Pull-Behind Ripper Attachment (A49461)
Pull-Behind Ripper...
2010 FORD F150 WORK PICKUP TRUCK (A51222)
2010 FORD F150...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
1984 AM GENERAL HMMWV HUMVEE (A51222)
1984 AM GENERAL...
