Grease fitting repair
/ Grease fitting repair #1
mhagerty
Hampstead, NH
BX2230
Hey guys, need some help with a hopefully simple repair. I was greasing up the FEL and snapped off a fitting. My question is how do you remove the remaining piece that is left in? What tool do I need to buy and any tips that I should know.
Thanks in advance for you help!
Mike
/ Grease fitting repair #2
Buy a very small screw extractor for that job. Although sometimes even a very small screwdriver works. And I know nothing about the company in the link; just the first good picture I found of a screw extractor (or as we used to call them, an EaZ Out).
/ Grease fitting repair #3
I had the same thing happen. Used a screw /bolt extractor. I think it was a kit of different sizes I got from Sears awhile back. I think they were on sale at the time and only cost a couple of bucks.
It's easy 'cause the fitting is hollow, no need to drill. Got some grease fittings at a NAPA store. /forums/images/graemlins/cool.gif
Eric P.
/ Grease fitting repair #4
This could be a good place to get information, but we don't know what kind of loader you're working on, or where you are located, filling in your profile would help a lot.
I broke one of the fittings in my 60 in. MMM and borrowed one out of my FEL to grease the MMM. When I went to replace the borrowed fitting, I assued that the Kubota loader would have metric fittings, so that is what I bought at Tractor Supply. When I went to replace the fitting, I needed the standard thread fitting. If we knew what you were working on, someone could possibly let you know what you need and where to get it. Tractor Supply also has the tool to remove broken fittings. Since you didn't fill out your profile, all this info may be totally useless, but I wasn't doing anything else anyhway.. /forums/images/graemlins/grin.gif
First, thanks for the replies!
Sorry about the lack of info. The fitting is from the LA211 (BX2230). It's the fitting down by the bucket (there is one on each side).
Are the fittings on the LA211 metric or standard? I’ll buy from Tractor Supply if they have a specific tool for it otherwise I'll pick up an extractor set.
Mike
/ Grease fitting repair #6
Mike, I can't say for sure on your rig, but I think that everything is metric on the tractors and SAE on the loaders for Kubotas.
/ Grease fitting repair #7
use a #2 easy out, do not use a # 1, they break off to easy. well you can use a # 1 but if requires very much pressure STOP! SWITCH TO A #2 , if the #2 is to big for the little hole drill the hole and make it bigger. the drill size should be engraved on the side of the easy out.
/ Grease fitting repair #8
Same thing happend to me, but it was a right angle zerk at the top of the left arm. My neighbor tried an EA-Z-Out but it was too tight and broke. He took it out and took it home and used a Tap and Die set on it. It depends how tight it is. I would try what fish_whisperer said in the post above mine.
Regards
/ Grease fitting repair #9
just another note,,,,, if you drill into the old zerk first hold the new one up and estimate how deep you need to go to get through it then put a peice of tape on the drill bit, wrap it around the bit so when you get to the tape thats far enough. if the easy out dont grab good enough, grind a little off the end of it to make it shorter, this will make it fatter so it will grab better.
/ Grease fitting repair #10
Thanks guys! I pick up a set of extractors so I will give it a try today.
Mike
/ Grease fitting repair #11
The fittings on the LA211 are standard SAE, and so are the fittings on the MMM, don't know about on the tractor since I haven't replaced one yet. Hope you get it fixed. /forums/images/graemlins/cool.gif
/ Grease fitting repair #12
Count me as another agreeing with Fish. Pay attention to what he said about using a no.2 EZ out. If you break one off it will be an enormus pain to recover from.
CASE TV370 SKID STEER (A62129)
CASE TV370 SKID...
40in. Skeleton Bucket Excavator Attachment (A61567)
40in. Skeleton...
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
Black Jet Dock Drive-On (A59228)
Black Jet Dock...
2019 COLEMAN BT200X MINI-BIKE (A64280)
2019 COLEMAN...
(4) 10-16.5 Tires (A65640)
(4) 10-16.5 Tires...
