Gravel Road Dust Control
/ Gravel Road Dust Control #21
When I was out in Colorado someone told me they use mag chloride on dirt roads. Those roads were more like blacktop as the dirt was bound together. Dry Magnesium Chloride | MeltSnow.com I want to do something on my bit of road but I am not keen on a corrosive product as I do not live in the salt belt. My car could last another 20 years if I do not put something down that would cause it to get eaten up. Also my well is shallow at 60 feet deep and 30 feet from the road.
/ Gravel Road Dust Control #22
I have found around here that if you drive real fast back and forth, all the dust will leave the roadway to form a huge cloud. Its just a temporary solution but everyone here does it, so that helps keep it all in the air.
/ Gravel Road Dust Control #23
What are the effects of ice melting products on the gravel, dirt roads when freezing conditions return? Does the surface stay muddy, soft, sloppy, like when a road thaws?
/ Gravel Road Dust Control #24
I drive will freeze up just as it always has without it. The way the salt works is by properties to attract and retain moisture where as a lot of the specialty dust control chemicals actually make the dust particles bind to one another through a polymer or something similiar. Salt uses moisture to make the dust particles to bind to one another.
CaCL is highly corrosive but I'm not sure how much of that transitions to corrosion on vehicles when used during the summer. When it is used as a winter de-icer it gets caught in the snow and the treads throw it directly against the vehicle's metal. With dust control it gets dissolved and binds into the soil. I suppose caked on mud could act as a corrosive but I've never heard of it being an issue with summer dust control.
Hopefully somebody can give more first hand experience.
/ Gravel Road Dust Control #25
I won't say what we used on our roads and driveways as a kid........but it did involve recycling :D Zero dust lol
I have to find some CaCl for the plan to proceed. Stopped at the local supply place but they were pretty busy. I did ask and he said they might have some in back but not a large amount. My neighbor does pest control so he's going to check with his chemical supplier. I'm told the Lowes and HD may have it or can order it.
I was wondering how to attach my drip boom to the FEL but realized all I need to do is attach my tooth bar and then use nylon ties to attach my PVC boom to the tooth bar.
Tomorrow I'll line up the pipe, plastic hose and fittings I'll need. I think I have a source for the plastic drum. My gun club uses then as barricades for IDPA matches though it may be difficult to select any without bullet holes. :)
I'm planning on a drip pipe of about 6-7' of 3/4" or 1" PVC. How big should I Make the drip holes and how far apart? My first guess is 1/8" holes about 4" spacing.
So far as mixing, I'm going to add the water and correct amount of CaCl and let an air hose bubble through and keep it stirred. Low effort and it might work. Otherwise a drill and a paint or drywall mud stirrer.
/ Gravel Road Dust Control #27
Same here.
On another note, if you have any asphalt millings available they do a great job of keeping dust down. Usually sell for 10-15$ a ton plus delivery. They pack in real nice and form a layer on top of the dirt.
/ Gravel Road Dust Control #28
... Salt uses moisture to make the dust particles to bind to one another.
CaCL is highly corrosive but I'm not sure how much of that transitions to corrosion on vehicles when used during the summer. When it is used as a winter de-icer it gets caught in the snow and the treads throw it directly against the vehicle's metal. With dust control it gets dissolved and binds into the soil. I suppose caked on mud could act as a corrosive but I've never heard of it being an issue with summer dust control. ....
CaCL is perhaps the most corrosive and hygroscopic of the chlorides, with rock salt being the least of both. Here in lower MI the old saw is that winter road salt causes rust. Hardly as likely as CaCL, the common dust control/deicer on dirt roads/streets in most of the lower peninsula. It will draw moisture from humid air wherever dusts sticks (there's still some) and wick its way into every nook and cranny, where corrosion is exacerbated by warmer temps and 'muggy' days.
CaCL is popular for deicing & dust control because it's cheap and effective above all else. There will be trade-offs with what works best. Beet juice has been tried in several LP communities and warm temps elicited complaints of the odor. I'm impressed with anything (organics, lignen, etc) that have a neutral Ph. IMO, the less area one has to treat the more reason to pay a few extra bucks for better stuff. What we're never certain of is which one is worth the difference. :2cents:
btw: 2 friends that began with asphalt millings complained that it didn't stay in place during winter plowing sessions. Limestone didn't either, and 'G' somewhat regretted his 'upgrade'. (I blamed using a truck plow with no gauge buttons vs the FEL). 'B' went with concrete and regularly drops a wheel off the edge when plowing, creating nasty ruts. He won't even answer when asked if the millings weren't so bad after all ....
/ Gravel Road Dust Control #29
From past experience using it as a de-icing agent, other then the above mentioned very corrosive, it's pretty rough on leather too.
Years ago we were mixing up Ca Cl in salt for the roads. One fellow had wet leather boots on, and damp leather gloves. After they dried overnight next to a heat register at home, the toes turned straight up, and the gloves shrank. Both, too small for him to get back on. So just putting out some fair warning...
I know they make a product to keep dust down for use in indoor horse arena's. Not sure what it would do on a driveway outside.
/ Gravel Road Dust Control #30
We had a dirt road for years now it has been blacktopped but years ago the Township bought this liquid solution from Paper mills it smelt like Vinegar and that would stop the Dust.they would bring it by Semi-Tanker.they would do this twice a Year.
/ Gravel Road Dust Control #31
You couldn't do it today due to environmental concerns nor could you afford to with the prices but I have driven on oiled roads before and they are really nice. Last time I saw one was probably 15 years ago. They literally spray crude oil on the gravel road and it was zero dust. It soaks in to the dirt as well and doesn't make a mess of your vehicles.
/ Gravel Road Dust Control #32
Our county sprays CaCl for 100 yards on each side of your driveway if you give them a doctor's prescription(no kidding). They would probably be better off spraying all of the roads because not only does the CaCl keep down the dust, it greatly reduces washboarding. We have about a mile of township roads. The county charges us too much to spray them so we have our own plastic barrel connected to a PVC pipe with holes spray system. Remember the dust that is flying used to be the material that you hauled in to build up your roads so every few years the county has to rebuild what the speedy drivers have blown away, except where the CaCl has been sprayed. Summer salt application does not appear to damage metal like winter salt. At least none of our equipment that we move down the roads shows road spray salt damage like our car hauler trailer which gets used on salted roads in the winter but it must have some effect.
/ Gravel Road Dust Control #33
In my tricycle days in Lincoln Park they oiled the side street (Ferris) just around the corner from us. (once you're around the corner & out of sight a driveway approach counts as sidewalk. ;)) Really worked tho' & I get a familiar whiff of that odor again sometimes when passing a working well on the way North to hunting camp.
Last time I saw oil on a road(?) was thoughout a county park in Indiana, say 'summer of '71. btw: There's kind of an art to navigating slickery 'washboards' on a motorcycle and uh, not everyone has the 'er talent. :eek: ..... :eek: ..... :laughing:
/ Gravel Road Dust Control #34
must be a special oil. When I started dating my wife back in the old days her parents road was oiled yearly. For a month after oiling I had to spend a half day with bug and tar remover after very time I went to see her. Didn't matter what speed - the car was a mess. We got married before they oiled the road the next summer so neither of us would have to drive on that gooey mess again.
/ Gravel Road Dust Control #35
Gravel/clay roads used to be a common disposal site for all kinds of waste products...think Times Beach, MO...and I bet there is still a fair amount of that going on even now, since proper disposal can be really expensive.
I was going to mention Times Beach. It's not too far South East of my location. Used to drive through there all the time. It's now a county park. Russell Bliss, the fellow who spread the oil, sure caught **** for that operation. I'm not sure f they ever proved that he knew the oil was contaminated with PCBs. He should have used fryer oil instead. Might have been a tourist draw.
/ Gravel Road Dust Control #37
We used two types of oil back in my days.
One was used veggie oil from the fryer or sunflower oil. It was bio-degradable and still used today by the US gov.
The second was used motor oil or the unrefined oil (prior to processing for diesel, petrol, plastics, etc). It was thick and glue like and with tiny chunks to it. If it got on your car, the easy way to get it off was to spread butter on it. Somehow the butter made it soft and it could be easily wiped off the next day without damaging the vehicle paint. I first laughed at it when I was told that, but it soon was the only way I would clean our cars and others who couldn't get it off.
/ Gravel Road Dust Control #38
That's probably Lignin Sulfonate, nick named tree sap. I have used it several years and works as well as CaCl.
/ Gravel Road Dust Control #39
Thanks for sharing your experience.
/ Gravel Road Dust Control #40
Not directed to anyone in particular:
Salt will draw moisture from the air at >80% humidity. CaCl will do so at >20% humidity. Michigan uses both, and an awful lot of the latter. It will reduce dust, but what dust clings to your car/truck will attract moisture in typical weather conditions. (ie: humidity >40%)
If you don't understand this, just blame road salt for all the damage to your car. The uneducated masses will nod in agreement. ;)
btw, It's been a few decades since I lived on a MI road treated with CaCl, but to drive on it the day of application there would be spatters of 'mud' on lower body paintwork. They literally had to be chiseled-off if allowed to dry, so how well it holds dirt together is obvious. Accepting any trade-off is a matter of taste. t o g
2014 Infiniti QX60 (A62613)
2014 Infiniti QX60...
2013 Ford Explorer AWD SUV (A64557)
2013 Ford Explorer...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
2019 John Deere M15 Batwing Mower (A66285)
2019 John Deere...
2013 HYUNDAI HL770-9A WHEEL LOADER (A65053)
2013 HYUNDAI...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
