Gravel Driveway
/ Gravel Driveway #41
Don't have any personally but have looked at a lot of Landpride implements since I've already purchased and I wouldn't hesitate to buy Landpride. Seems like pretty good quality in the middle to high range of implements.
/ Gravel Driveway #43
Agred hazmat - wasn't refering to that particular implement - thought the question was the quality of Landpride in general which I think is pretty good if not cheap. That said as you indicated I would not just get a set of scarifiers when I could get them in conjunction with a box blade for about the same cost.
/ Gravel Driveway #44
Ditto on the box scraper for the same price. I just thought it was a cool idea that combined good things from both types of implements for road grading. I was quoted $499 for the SF2566 scarifier and $849 for the LR1584 rake with gauge wheels. Already found a used SF2566 for $350, so I wouldn't be buying new anyway.
/ Gravel Driveway #45
I have a landpride rear blade RB1560 & Rear Finish Mower FDR1560 (for now). Only a few hours to date. So far I'm impressed. The mower does an excellent cutting job. I used to mow professionally in my high school & college days. I'm still getting used to the RFM manuvering. The rear blade is ruggedly built and seems to work well (nothing to compare it to). I got it with skid shoes for snow plowing and they actually do their job and keep the blade above the gravel.
/ Gravel Driveway #46
No way would I put a 60" boxblade on a BX. I probably has enough power, but it doesn't have enough weight to maintain traction when a boxblade that big gets filled up.
I use a Woods 48" boxblade on my B7500. 95% of the time it's "just right", but if I fill it up with wet material, I can run out of traction.
The boxblade is a great tool on a small tractor. It takes a while to learn how to use, but once you get the hang of it, you wonder how you lived without it. I use <font color=orange>Lucy!</font color=orange> with that aforementioned 48" boxblade to maintain our 4300' gravel driveway. Does a great job, but takes several passes to work an area. It would be nice to have a bigger blade/tractor combination, but then I would have a major hassle getting the mowing done (anything bigger than the B7500 would have a hard time negotiating the tight places.
/ Gravel Driveway #47
Don't know how many of you are familiar with Gearmore, but they have a whole line of implements made for the BX series. They are of lighter weight, and not quite as rugged as the other units out there, but you can get alot out of them for a smaller price, not to mention the weight problems with the BX series.
/ Gravel Driveway #48
beenthere has the right idea. You have to get down into the packed gravel, loosen it, then mix it with the looser stuff on top.
If you don't get down below the washboards and the potholes you are just filling in the low spots and the fix is temporary.
I have a pretty deep bed of gravel on my driveway (8"-10") and the scarifers on my box blade just weren't getting down deep enough.
I hooked up my 3ph middle buster and plowed it up like I was getting ready to plant it! You should have seen the stares I got from the neighbors./w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif
After I plowed it up real good, I took the box blade and smoothed and packed it. That was 5 years ago and it is almost good as new today. Mine is fairly flat though so hard rain only helps it.
Good luck with your project.
TBone
/ Gravel Driveway #49
smthng2do,
Do you know if there is any info on the Gearmore BX implements on the Internet? I heard (from the list) that KK was doing a special line for BX-sized machines, but hadn't heard of any others. Thanks
Kevin
/ Gravel Driveway #50
The First Choice 15 Series box blades, rear blades, and rakes are set up as true Cat 1 spacing, but the lift pins are reversible for sub-compacts, such as the BX Series to hook up easily too. <A target="_blank" HREF=http://home.midwest.net/~jimmc/index.html>http://home.midwest.net/~jimmc/index.html</A> and are available in Kubota orange, NH blue, John Deere green, and Case red.
/ Gravel Driveway #51
You won't appreciate it till you try it, but Chim's idea works best for me. I have a box blade and a rear blade and a piece of angle iron. Now days I use the box blade till the road looks like a mess, then I fix all my mistakes with the angle iron. My rig is a piece of 12' long with a 26 foot steel cable. The cable is attached three feet in on each side and has a 2 foot loop in the center. The loop is made with one clamp. Attach this to your drawbar. You will be amazed at how quickly you can fix a mess with this thing. I have 50 HP so you might want a smaller rig.
2015 FREIGHTLINER SPRINTER 2500 CARGO VAN (A59905)
2015 FREIGHTLINER...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
SWICT 66" SKID STEER BUCKET (A60430)
SWICT 66" SKID...
2013 BUJ (A59231)
2013 BUJ (A59231)
Midwestern Industries MEV Screen Model MEV 5X10-2 (A61306)
Midwestern...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
