Gravel drive dust control
/ Gravel drive dust control #1
greenthumb
SE/Mid Michigan
tc40, exmark lazer Z
Anyone ever spread calcium chloride pellets on gravel drive to keep dust down. I'm thinking of trying it on our drive. I have a broadcast pull behind spreader and a drop spreader that I could use. Wonder if it would work.
/ Gravel drive dust control #2
I am not sure of how it would help with dust control but when you mix it with water it is highly corrosive on metal pats. Calcium Chloride and water is what most tire places use to put fluid in tires for extra weight, doesn't hurt the rubber tires or innertubes but I have seen it eat the valve core out of a tube and have seen many rims trashed because of leaks. I can't even imagine what that will do to the underside of your vehicles when it rains.
/ Gravel drive dust control #3
When I was a kid (1950s in Tenn) they use to spray used motor oil on the gravel roads to combat the dust. I doubt you would get away with that now.
/ Gravel drive dust control #4
Calcium and Magnesium salts are commonly used for dust control. They're hydrophilic (enjoy water), so they have a tendency to keep moisture at the road-bed surface.
IME they aren't the greatest for household driveways, because they can make some dirt stick to your feet- which then gets tracked into the house.
/ Gravel drive dust control #5
I did exactly as you are describing at our last house on the gravel road that went by...Worked great. There were dry spells where I would have to spray some water on the road to keep it active but usually just the periodic rains and morning dew would suffice.
/ Gravel drive dust control #6
1*I doubt you would get away with that now.
2*I'm thinking of trying it on our drive. I have a broadcast pull behind spreader and a drop spreader that I could use. Wonder if it would work.
1*Why not it's his own drive weay?
2*Don't even think about it.
/ Gravel drive dust control #7
My buddy has his lane done with a by-product of the dairy industry. They spray it on and it lasts all summer and there is no odour. Not sure exactly what it is but may be able to find out.
/ Gravel drive dust control #8
If you spray any chloride product you'll attract critters, they like to lick it. When I was in Maine the moose were standing all over the road licking the gravel after they spread that stuff.
/ Gravel drive dust control #9
sure we still do it mix burnt motor oil thin it with some kerosene and that works alot better than putting salt on it then paying to fix rust on your car or truck :thumbsup:
/ Gravel drive dust control #10
There is a polymer based on soy oil used for the purpose. I think even miltary uses that to make dust free landing pads for helicopters. It is expensive though. The company that makes such product is called Dustkill.
Dream farmer how much did you use. And did you just by the stuff you would use for ice melting
/ Gravel drive dust control #12
I got some crushed asphalt delivered and spread. That solves the dust problem completely. Plus it stays put. Rake and manage just like gravel.
/ Gravel drive dust control #13
Quote:
sure we still use it used motor .:thumbsup:
Around here the County can spray it by the barrel full on the gravel roads .
The state just recently put gravel burms along the state highway then came back through in a coupls days and sprayed the graved with dirty used oil .
Yet let me accidently spill some of a quart of clean oil on my drive way or in my yard and the EPA would be all over me in full force.
/ Gravel drive dust control #14
Pave it, thats what I did 3 years ago. My drive is 280' long and 40 feet wide at the barn. 4,600 SQ total and its the best $7500 I have ever spent. I hated gravel.
Chris
/ Gravel drive dust control #15
Use the flakes, not the pellets. They also use some type of beet juice for this.
2023 Tesla Model 3 Sedan (A66738)
2023 Tesla Model 3...
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
2025 Future FT-D680 (A64912)
2025 Future...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A68183)
2023 Caterpillar...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
1024 (A63111)
1024 (A63111)
