Grasshopper 925 Front Mount Grease Fitting
/ Grasshopper 925 Front Mount Grease Fitting #1
reevesjo
Wilkinson, IN
Grasshopper 725
Any good way to grease the front driveshaft pillow block zerk without removing the mower deck?
FORGET THIS. After blowing the dirt and grass away, I can now see the zerk is on the forward side of the pillow block "where it should be"'. I had forgot since the last time. Problem solved!!
/ Grasshopper 925 Front Mount Grease Fitting #4
I blow off the grass around that area on my 725 Grasshopper every time I'm done mowing. It seems to collect there and I once had it get packed in pretty hard. While I'm blowing that area clean I also blow out the radiator and screen. Doesn't hurt.
To grease that front bearing I use an extra long clip on grease chuck. It makes access easier and the clip on aspect assures I get grease in the fitting
