dodge man
Super Star Member
The battery one are heavier but then you don’t have to pump it. My Dewalt has a fairly long hose, I can usually find something to test it, a loader are for example.
Unless you have RA. But pumping a lever is the least challenging--It's getting to the fittings and being in a position to pump the lever at the same time. I won't give up my electric gun. Besides, I'm 72 now and won't be around in 50 years to care one way or the other.It takes so little effort to operate a lever gun, it's nothing.
Tis the season to be crabby I guess.On a side note:
It's sad that so many are so tightly puckered they don't have a sense of humor.
I wouldn't be surprised if it would. I was going to say it wouldn't do much good but then I recall that you use bulk.I woder if the clear grease gun barrels I use will for the electric grease guns?
That is correct. If you use a grease tube. it won't matter as you cannot see how much there is. I have this thing about handling grease tubes anyway. you get greased putting them in and pulling them out. I don't have that issue.I wouldn't be surprised if it would. I was going to say it wouldn't do much good but then I recall that you use bulk.
I'm glad your having good luck with your old grease gun.LouNY I have been using my grease gun
since 1971 that's over 50 years and it still
works GREAT!!! With the rubber hose
attachment I have never had a problem
getting to any fitting! I will be 83 in a few
months. I have no problem pumping the
handle just hold the nozzle on the fitting
grab the barrel and push the handle against
what ever is available! works like a charm
I can purchase a bucket of grease for the
price of an electric grease gun! If you like
the electric grease guns enjoy. I will not
purchase a new car because of all the gadgets
that are electronic prone to failure! Just to
replace the radio in out car cost is over
$2,000 and it will probably last about 14 months
I don't need a screen to tell me where I'm going
and that Sirius radio is like a case of hemorrhoids
something I can do very nicely without! Also
the so called music today I can do very nicely
without! I record music and then I have what
I want to listen to with out commercials no less!
I can tell very quickly when the tube is empty
willy
There’s also a shoulder strap you can use to hang the GG off you leaving both hands free.Some of the comments on here are rather humorous... Electric too heavy...oh my! I love how I can set it on the ground or a tire and the long hose reaches all the zerks on most of my equipment. Changing a tube is too messy!??? I can do it without loosing any grease. Maybe I should make a video on that one.
Back to the topic: I just pull on the rod and I have a good idea on how much grease is left.
I'm not sure about yours, but the 18 - 20V adapter won't fit my old DeWalt greaser.For Christmas I’m hoping Santa will bring me a 18 volt to 20 volt adapter and a couple of batteries.
Probably not too many of us will be working in 50 years as well. You must be a youngster if you're thinking 50 years ahead.Well..... Not a single one of our electric grease guns will be working in 50 years, so he does have a point!
