Grass in driveway - Removing
   / Grass in driveway - Removing #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
For some reason I like grass in my yard, but not in my driveway. I used the snow blade today to scrape the driveway and removed most of the grass. I left the rubber edging on it because I am lazy (It does not have a quick attach). Does any one have suggestions on how to improve on this and their results using various implements?
Bob Rip
   / Grass in driveway - Removing #2
A landscape rake works pretty well for this purpose, and redistributes the gravel at the same time...
   / Grass in driveway - Removing #3
I'm assuming your driveway is rock or stone. ??
Depends if you are willing to use chemicals or not.
If yes, them something like Ortho Cleanup works well. Kills everything. If you don't want to use chemicals, get a rake and rought it up once in a while but be prepared to do the never ending battle. To help lessen weeds, never mow towards the driveway, as it blows the seeds into the drive in disproportional numbers. Mow towards the neighbor's yard! /forums/images/graemlins/grin.gif
The driveway is gravel. Thanks for the tips.
I have used chemicals, but it takes a lot (the driveway is about 300 feet long, and 30 feet wide for about one hundred feet). Also I never seem to get rid of most of the grass. I will have to borrow ClintBlake's rake and try that.
Bob Rip
   / Grass in driveway - Removing #5
</font><font color="blue" class="small">( because I am lazy )</font>
<font color="red"> Since, like most of us, you want to use your PT for every possible job, I suggest that you buy a young goat and 15' of rope. Tie one end of the rope to the goat and the other end to your PT. Each day move the PT 15' along the driveway. Come Thanksgiving, rather than turkey, you can have a Jamaican barbeque!!
</font>
   / Grass in driveway - Removing #6
BobRip,
The box blade works very well for this task. By the way, I know someone local that would probably loan you one if you are interested.
   / Grass in driveway - Removing #7
I've had good luck with Roundup. Be sure and get the real stuff that farmers use not the diluted product sold to the general public. I sprayed mine twice the first year and have only had to spot spray since. You can get a 15 gallon sprayer and mount it on your PT; maybe even make up a spray boom from parts from the local farm supply. I mounted mine on my ATV so I could spray really fast. /forums/images/graemlins/grin.gif
I have tried regular Roundup and have had poor results. I am going with the scraping for now and see how it holds up. It took less that an hour to scrape the driveway and no materials to buy.
Thanks,
Bob Rip
   / Grass in driveway - Removing #9
I like to use <font color="red">fire</font> to keep the grass and weeds at bay. Flame weeding can be a very good alternative to chemicals.
I've been happy with the stuff I have purchased from:
Red Dragon
I bought a flame weeder yesterday. It works great. How long will the grass stay gone?
Bob Rip
   / Grass in driveway - Removing #12
<font color="blue">I bought a flame weeder yesterday. It works great. </font>
<font color="red">How do you use one of those things? Do you keep the flame on until the plant's completely burned up or do you use it to just scorch the grass? </font>
   / Grass in driveway - Removing #13
That grass will probably come back in a couple of weeks. You should also use a chemical grass and weed killer, so it can get down to the roots If you want to go cheap, try rock salt on the cracks.
   / Grass in driveway - Removing #14
For me, the best process and results are achieved by using a total vegetation killer (round-up or similar) on the weeds then wait a week and then burn off. They burn very quickly once dead.
   / Grass in driveway - Removing #15
I use roundup on my driveway. Mix it a little stronger than it says on label and do it on a real sunny day , prferably hot but necessarily, but the sunnier the better the weeds will take the roundup right in and kills the weeds,
   / Grass in driveway - Removing #16
I just mow the gravel driveway. The grass helps control erosion, IMHO.
Besides, where else would the deer, rabbits, and groundhogs graze together, if we had no grass in our driveway? /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
   / Grass in driveway - Removing #17
<font color="blue">First off i think that the chemical killers work very good and are a lot easier to apply...But alas, we live next to a creek w/salmon in it and I was just reading a report about water quality. It said that the rivers and creeks around here had a significant amount of pesticides, some from ag and some from residential. I found it interesting that the report thought that the residential contribution was more of a problem, and it was surmise because we don't read and understand the directions so we have a tendency to over apply and at the wrong times. So I'm gonna try the blanket harrow, weed burner....and anything else that come up here</font> /forums/images/graemlins/grin.gif
oh ya for you diyers
http://www.agronomy.ucdavis.edu/LTRAS/itech/flame.html
   / Grass in driveway - Removing #18
Bob,
Here is another idea to consider.
I use Horticultural Vinegar. The product is made by the acetous fermentation of ethyl alcohol (made from grain) containing 20% acetic acid (200 grain food grade vinegar). Yucca Extract (food grade Yucca Schidigera), a sticky carbohydrate substance, has been added as a natural surfactant.
Of the many uses, one is to use as a non-selective vegetation killer. The killing action is a dehydration process. The acidity of the vinegar strips the protective coating off the surface of a plant.
Best used in hot weather. I like this product as you can replant in about an hour.
Product is cheaper than most products but not many places carry it.
I have ordered it through Bradfield Industries, Inc. 417-882-1442. You can also find information on this product at www.bradfieldind.com.
I have no connection with this company so you may find other sources as well. I ran into them at a nursery trade show.
PJ
Thanks for the tips. I am going to see what comes back. My past experience with round up is that a lot of grass is not killed.
According to the instructions you don't have to completely burn up the grass. They say fan over it at a slow walk will do it. We will see.
Bob Rip
   / Grass in driveway - Removing #20
hmmm vinegar and hot steamy grass. Kinda reminds me of sauerkraut. /forums/images/graemlins/grin.gif
2025 40ft 10-Door Shipping Container (A59228)
2025 40ft 10-Door...
2017 Ford F-550 Service Truck (A59230)
2017 Ford F-550...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
2015 Forest River Rockwood Freedom S/A Pop Up Trailer (A59231)
2015 Forest River...
