Grass and leaf pickup, what do you use, recommend?
   / Grass and leaf pickup, what do you use, recommend? #1
Volfandt
Veteran Member
TN
2004 Kubota BX23, 1966 WheelHorse 856
Greetings,
Sitting here looking at the aftermath of a pretty serious storm, I can't help but notice all the leaves that are now covering the driveway. This of course leads me to think of the upcoming fall season, which is aptly named btw., and what I plan to do about leaf pickup. Last yr I had a no tools needed twin bagger attachment for my lawn mower and it did a very good job, except with only two bags I made mucho trips to the compost pile. Even at that it was fine as it was seat time but I've since sold that rig and now am faced with coming up with a plan of attack not only for the fall but grass clipping pickup too! My homemade mulch plug does OK in the front but I have to remove it for the back.
Since I'm useing the compost from yrs past and I like the clean look after running a bagger for grass/leaf pickup, I'm sold on using a bagger of some sort.
So heres the choices as I see it.
1) Kubota bagger. I've read where it's performance is outstanding but is a pain to R&R. Also it's the most expensive solution.
2) Kubota Mulch kit. I've read where it's performance is outstanding but it is not designed for R&R. Altho I've read about it's grass clipping performance, I don't recall reading about what it does in heavy and I do mean HEAVY leaf mulching.
3) Cyclone Rake, it has it's own 5hp power plant and will hold much more debris than Kubota's bagger. The hopper is made of some sort of treated fiber material but the frame is aluminum. It mounts ridgidly and pivots on two casters. Folds up and can be hung on the wall except for the engine module which rolls out of the way. Pluses is the cost, around $1,200.00 and it's stowability.
4) DR LeafVac, like the Cyclone Rake it mounts ridgedly to the tractor and pivots on two casters but it's hopper is made of plastic. The intake technology lays claims that it doesn't generate near the dust/exhaust of all the other baggers. Also claims to chop up the debris much finer due to teeth on the impeller.
Another plus is the 6 & 7hp models also incorporate a chipper shreader that can handle branches upto 2" thick.
Negatives seems to be a lack of compact stowabilty and the 6hp model runs approx $500 more than the Cyclone Rake.
5) Tow behind sweeper. I've had a sweeper before and the lack of capacity along with it's inability to work in damp grass/leaves makes this the least desired solution, for me anyways. I sold mine when I went to a bagger and I said then that I wouldn't go back /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif Course this is the least expensive option so it deserves mention.
Comments, recommendations?
Volfandt
   / Grass and leaf pickup, what do you use, recommend? #2
This is what I use, and it is probably closest to your #4. With a hydraulic dump, it is effortless. The top folds and it tucks away in a small shed in about a 4'x 4' x 2' space.
Sorry for the 'green' color in this forum of orange. /forums/images/graemlins/blush.gif
   / Grass and leaf pickup, what do you use, recommend? #3
I bought a Trac-Vac a few months ago. It does a great job picking up the grass.
   / Grass and leaf pickup, what do you use, recommend? #4
I have sweeper and after 800 trips to the debris pile each fall I am seriously interested, and have been looking for a while, at the Cyclone Rake. The Platinum, fyi, is actually 6 HP and the Commercial version is 7HP. I think it is reasonable to consider that by the time you upgrade all the components of this system; the urethane heavy duty hoses, the 32' Estate vacum pickup attachment, roof rack carrier for it, the remote discharger hose (don't forget to upgrade those) {you can water, heavy, your evergreens for winter and then discharge the leaf mulch as a cover to prevent evaporation - till it in the spring} consider the dual wheels as the 32 bushels of the commercial version is bound to get heavy, and don't forget the power bagger folding dividers so it will auto fill 6 bags(!) and you are looking at $2K. Of these units, however, I have never heard anything but praise. Albeit, the discount price, which seems to always be available, $1275 (tractor not included /forums/images/graemlins/grin.gif), is not what you'll end up spending. /forums/images/graemlins/cool.gif I'm still looking at these. /forums/images/graemlins/smile.gif
   / Grass and leaf pickup, what do you use, recommend? #5
I have been using a Cyclone Rake for the last 5 years and it has performed great. My only regret is that I didn't purchase the commercial version as I have so many leaves i still need to dump it about 10 times. It does mulch them up pretty good. I usually make a couple of large piles of leaves that get compressed over the year. When aged I till them in the garden. I also really like the hose attachement that allows me to clear the fence lines and around the landscaping.
It folds up and stores very nicely and out of the way. One negative is that it does get a little dusty so bundle up and wear a hat.
   / Grass and leaf pickup, what do you use, recommend? #6
How about a couple of Cub Scouts. Good way to earn thier den dues /forums/images/graemlins/grin.gif
Funny, it sure is hard to find kids to work in this generation. When I was a kid, a little yard work for the neighbor was a great way to earn some pocket change.
   / Grass and leaf pickup, what do you use, recommend? #7
I've been very satified with the OEM Kubota grass/leaf catcher on my BX. It is well made and very powerfull with no extra pony motor.
   / Grass and leaf pickup, what do you use, recommend? #8
I have the Kubota grass catcher on my BX2200 and it does a great job on leaves and grass clippings. With practice getting it on and off gets easier. I paid about $1,400 as I recall. Running off the PTO was the selling point for me as I already have too many engines to maintain... (just don't tell my wife I said that...)
   / Grass and leaf pickup, what do you use, recommend? #9
I have a TracVac similar to JonM's. Mine initially had a 5hp BS engine and I replaced it with a 6.5 BS when the motor went after a number of years. I believe they may make a PTO version as well.
It works just fine for the most part, although sticks that don't get chopped up sufficiently by the mower will clog it (duh !) One nice feature is that the hopper is narrower in the front than in the back which allows whatever you are picking up to come out easier when you dump. A couple of the downsides are: 1. it's big - you need room to store it, and 2. being made out of steel it's not a good idea to leave it out in the weather.
   / Grass and leaf pickup, what do you use, recommend? #10
Nothing a little paint and some proper decals won't fix...
/forums/images/graemlins/wink.gif
2018 INTERNATIONAL 4300 NON CDL 26FT BOX TRUCK (A59904)
2018 INTERNATIONAL...
2014 Ford F-350 Pickup Truck (A55973)
2014 Ford F-350...
KOMATSU HM400-3 OFF ROAD DUMP TRUCK (A60429)
KOMATSU HM400-3...
2018 KOMATSU PC88MR-10 EXCAVATOR (A60429)
2018 KOMATSU...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
