Grapple
/ Grapple #73
Moemoe,
Nice job on the grapple. One more little addition you might want to think about is adding a brace to the bracket holding the back of the ram. Maybe you already have one on there, I couldn't see the back from the pictures you posted. I found with the one I had built that there is a lot of stress in that area. I just broke mine. I was picking and loading wood. The height of the rear bracket leaves it prone to problems. A quick brace will do the trick for you.
/ Grapple #74
Moemoe,
/ Grapple
Thanks for mentioning the brace. I found after moving about 3 logs it did start to bend ( weakest link) So I did add a brace from the bracket to the where the grapple is pinned to the tubing. I don't think you can see it in the pictures. Anyway no problems since, and I have moved about 50 logs since some alot bigger than in the picture but needed to add balast to the rear end.
/ Grapple
/ Grapple #77
Moe,
Looks great, I bought a two arm grapple and tooth bar because I'am not set up yet for welding.
Have you regretted going with a single cylinder? Have you used it with the tooth bar yet? Been worried if my set up is going to handle the medium cedars I need to stack.
Grapple came with a 6" cylinder but I am thinking I will need a 8" the grapple is 32".
/ Grapple #78
Moe,
/ Grapple #79
I'm curious to see if you need to move one of the teeth on the tooth-bar. In my case the center lift arm on the grapple interfered with the center tooth so I repositioned it a bit to the side of dead center..
/ Grapple #80
2016 Dodge Journey SUV (A59231)
2016 Dodge Journey...
Freightliner Columbia (A61307)
Freightliner...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2021 Kubota SVL75-2 Track Loader (A61307)
2021 Kubota...
