Grapple
/ Grapple
I already made a toothbar sparkkky. Just didn't put it on while I was fitting the grapple.
/ Grapple
Thanks for getting back to me PineRidge, I have a relay already, just not sure how to wire it up, so if you could send me the diagram.
/ Grapple
/ Grapple #67
I hope you don't take off points for neatness. /forums/images/graemlins/grin.gif
/ Grapple #68
/ Grapple #73
Moemoe,
Nice job on the grapple. One more little addition you might want to think about is adding a brace to the bracket holding the back of the ram. Maybe you already have one on there, I couldn't see the back from the pictures you posted. I found with the one I had built that there is a lot of stress in that area. I just broke mine. I was picking and loading wood. The height of the rear bracket leaves it prone to problems. A quick brace will do the trick for you.
/ Grapple #74
Moemoe,
/ Grapple
Thanks for mentioning the brace. I found after moving about 3 logs it did start to bend ( weakest link) So I did add a brace from the bracket to the where the grapple is pinned to the tubing. I don't think you can see it in the pictures. Anyway no problems since, and I have moved about 50 logs since some alot bigger than in the picture but needed to add balast to the rear end.
/ Grapple
/ Grapple #77
Moe,
Looks great, I bought a two arm grapple and tooth bar because I'am not set up yet for welding.
Have you regretted going with a single cylinder? Have you used it with the tooth bar yet? Been worried if my set up is going to handle the medium cedars I need to stack.
Grapple came with a 6" cylinder but I am thinking I will need a 8" the grapple is 32".
/ Grapple #78
Moe,
/ Grapple #79
I'm curious to see if you need to move one of the teeth on the tooth-bar. In my case the center lift arm on the grapple interfered with the center tooth so I repositioned it a bit to the side of dead center..
/ Grapple #80
CATERPILLAR D6N LGP HI-TRACK CRAWLER DOZER (A65053)
CATERPILLAR D6N...
2011 JCB 4x4 Backhoe 3CX14-4-T (A65579)
2011 JCB 4x4...
(4) Ratchet Straps (A65583)
(4) Ratchet Straps...
2012 FORD E-350 CUTAWAY SERVICE BODY TRUCK (A59914)
2012 FORD E-350...
NEW Wolverine GB-11-72W Skid Steer Grapple Bucket (A62679)
NEW Wolverine...
2004 Club Car Carryall 6 Medical Utility Cart (A64553)
2004 Club Car...
