Grapple
/ Grapple
I already made a toothbar sparkkky. Just didn't put it on while I was fitting the grapple.
/ Grapple
Thanks for getting back to me PineRidge, I have a relay already, just not sure how to wire it up, so if you could send me the diagram.
/ Grapple
/ Grapple #67
I hope you don't take off points for neatness. /forums/images/graemlins/grin.gif
/ Grapple #68
/ Grapple #73
Moemoe,
Nice job on the grapple. One more little addition you might want to think about is adding a brace to the bracket holding the back of the ram. Maybe you already have one on there, I couldn't see the back from the pictures you posted. I found with the one I had built that there is a lot of stress in that area. I just broke mine. I was picking and loading wood. The height of the rear bracket leaves it prone to problems. A quick brace will do the trick for you.
/ Grapple #74
Moemoe,
/ Grapple
Thanks for mentioning the brace. I found after moving about 3 logs it did start to bend ( weakest link) So I did add a brace from the bracket to the where the grapple is pinned to the tubing. I don't think you can see it in the pictures. Anyway no problems since, and I have moved about 50 logs since some alot bigger than in the picture but needed to add balast to the rear end.
/ Grapple
/ Grapple #77
Moe,
Looks great, I bought a two arm grapple and tooth bar because I'am not set up yet for welding.
Have you regretted going with a single cylinder? Have you used it with the tooth bar yet? Been worried if my set up is going to handle the medium cedars I need to stack.
Grapple came with a 6" cylinder but I am thinking I will need a 8" the grapple is 32".
/ Grapple #78
Moe,
/ Grapple #79
I'm curious to see if you need to move one of the teeth on the tooth-bar. In my case the center lift arm on the grapple interfered with the center tooth so I repositioned it a bit to the side of dead center..
/ Grapple #80
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
Pemberton Inc 416469 72in. Loader Forks and Frame (A64194)
Pemberton Inc...
Cattle Feeder (A65640)
Toro Reelmaster 4000 D Mower (A65579)
Toro Reelmaster...
Aluminum Turtle (A65583)
Aluminum Turtle...
