Grapple Grapple "jaws" won't close
/ Grapple "jaws" won't close #61
[snip]
I just need the thing back so I can clean up the mess - my OCD is in over-drive - the piles of limbs are right in my line of sight from my chair in our living room!
The only thing worse about not owning the right tool is owning it, but not having it with you when you need it!
/ Grapple "jaws" won't close #62
Good to see you're (probably) back in business - I share your OCD, sometimes to more of an extent than I'd like :laughing:
IF you want to understand QD's a bit better, here's one scenario that can happen (possibly yours)
The ag type QD's are typically either ball or "poppet" type, and both types have a common design flaw - both halves of a QD pair, whether ball or poppet, have a SPRING behind the sealing item (the ball) - this is the part that keeps MOST of the hydraulic fluid from ending up on the ground when they are disconnected.
When you put them together, BOTH halves' springs compress, allowing BOTH balls to move away from their respective seat, and fluid is then allowed to move thru the (restricted somewhat) passage AROUND the balls.
BUT....
If either one of the springs fails (breaks, or relaxes due to metallurgical failure) then that pair of QD's becomes either a partial (low flow) or TOTAL CHECK VALVE -
This will either partially or TOTALLY block flow, but ONLY in ONE direction - ("my cylinder will extend, but won't retract")
If you actuate the control valve to cause flow from the bad side toward the GOOD side, you WILL get flow because the pressure will push the GOOD ball and spring away from their seat.
BUT - going the OTHER direction, there is nothing but a broken (or weak) spring to push the GOOD ball/spring away from its seat, so NO (or little) flow.
There's more, but hopefully this will help explain what can happen and why it can get pretty confusing... Steve
/ Grapple "jaws" won't close #63
BUT....
That's a good, accurate way of explaining something that's pretty hard to explain. :thumbsup:
Good info!
Travis
/ Grapple "jaws" won't close #64
+1. Great post, BukitCase!
IF you want to understand QD's a bit better, here's one scenario that can happen (possibly yours).........
I agree Bukit, that sounds a lot like what I had going on.
Thanks for the explanation!
/ Grapple "jaws" won't close #66
BUT....
That is a heckuva fine, easy to understand explanation. I like it!
/ Grapple "jaws" won't close #67
Here ya go, Eric ..... I must respect the internet rules! :
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A65053)
2019 VOLVO A45G...
2014 Grand Caravan (A62679)
2014 Grand Caravan...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
2011 BRENNER TANK TRAILER (A65643)
2011 BRENNER TANK...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
