Grapple Grapple feedback
/ Grapple feedback #1
archeryantny
Hillsborough NJ
Kubota L48
/ Grapple feedback #2
Those are pretty popular...as well as a similar one (I think possibly the original one) made by Andy Tatro.
Search the word "tatro" for lots of reading on them...
/ Grapple feedback #4
I would think it depends on your use. If you use your bucket to pick up building debris from a pile and just need to hold it in the bucket, I think this would work great. But if you use it to rip up small trees and overgrown undergrowth, I think you need the bottom "teeth" of a regular root type grapple to dig and slide under the roots so you can lift them up before you clamp them with the top teeth. I just bought a Markham grapple. Although it is more that the E-Bay item, it also included the hoses and quickconnects that would probably run another $100, and it requires no welding or installation. It would also free up your bucket to use as a regular bucket without the top arm getting in you way. A 48" Markham light duty (which is still pretty stout) runs about $900 but if you factor in the hoses and installation, the gap narrows, and it will work way better for the use I mentioned. Just my opinion. You also will need to consider what quick connect your tractor has, because that could jack up the cost. Currently Markham makes a skid steer type and a John Deere type connection. If your tractor has one of those, you are in business. They could probably make any type you need, as they are good to custom build anything. Hope this helps.
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
2011 BMW 5 Series 528i Sedan (A61574)
2011 BMW 5 Series...
2006 Reefer Trailer (A64194)
2006 Reefer...
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
2017 Autocar Xpeditor T/A Heil V-161 Front Loader Garbage Truck (A61573)
2017 Autocar...
