Grapple Design
/ Grapple Design #121
Dave,
Your grapple sure is looking good, very beefy for sure.
Re Pictures:
I want them smaller in the board, but click able any help?
If you have a photobucket account, just click the little box next to the photo, then go to the bottom of the web page, then push the button "Generate HTML and Image code" then click the code in the box "IMG clickable thumbnails for message boards - recommended" The code will be copied to the clipboard, simply paste the copied code into the TBN thread. Then Viola! you should have image clickable thumbnail pictures. Like this:
Larry
/ Grapple Design
I think I should be able to end this thread by the end of this weekend. It has been a long process, but I think I will be happy with the outcome. I'm going to try to finish up the welding tonight.
/ Grapple Design #124
DTD,
Man, that is looking really NICE!!!
What is the total width, at the outer grapple teeth?
And what is the width of your bucket?
Just trying to see what kind of "grab" you will have, in relation to your overall bucket width.
Looking reeeeal good!!
/ Grapple Design
Skunk,
The overall width of tooth to tooth is about 42" +/-. The barcket on the bucket is 46" and the bucket itself is 73". So about 15" from tooth to end of bucket.
I was at TSC and they have what looks to be the best paint selection. I figure an implement paint prime and I think match the wheel wells using JD yellow (is that is such a color).
Very ready for the grapple. I just piled up my 27th project for it.
/ Grapple Design
Figured you guys would appreciate some pics of the shop as well.
/ Grapple Design #129
Wow, great pics dt.
Your grapple should be done pretty soon and working then, huh?
Geez, you got a lot of stuff in your garage. I couldn't fit all mine so I had to get rid of it and keep only what fit. Now I wish I'd kept some more to put some in my new barn. Your shop is well equipped man.
/ Grapple Design #130
Nice job. I really like the wider than average grapple arm and the moderate underbite.
Now we need you to get out of your shop and snag some "grapple in action" photos.:)
/ Grapple Design
It's actually my step father's shop. He's the metal guy!! He really did a great job as usual. I like the bolt stops and linement stops. Those are things I wouldn't have thought about. (1) 1-1/2 socket to get this thing on and off. Bringin her home tonight!!! Only thing left is the plumbing. I have to move the plumbing to the front of the tractor. I put them on the brush guard which just doesn't work.
Anyhoot, I promise pics of the grapple in action by the end of this weekend.
I don't want to get ahead of myself, but I couldn't have completed this project without the help of all you guys that chimed in from the begining of this thread (Feb 6, 2007), TBN, and of course my step father for really giving me the opportunity to be able to build a project like this as well as all his time and meticulous effort.
This is really the first tool I have ever designed and built. Actually the first project using metal.
Thank you!!!!!!!!!
/ Grapple Design #132
DTD, excellent! and great pics!
if this is your first metal project, and you have that kind of help, I can't wait to see your 2nd and 3rd projects!!
Good show.
"Grapple Action" pics..... eagerly awaiting them. ;)
You will be grinnin ear-to-ear, of that I am sure. :D
/ Grapple Design
Man this thing came out great!!! Only thing wrong is the cylinder is very fast and touchy. Is there such a thing as an adjustable regulator for hydraulic line going to front of FEL? I will just be easy on it for now. It's alot more action while using the tractor. I put in as much seat time as I could this weekend!!! Glad I did the work light project before this one!!!
Here are the operating pics as promised
/ Grapple Design #134
You could put in a restrictor bushing in the hydraulics to slow down the grapple. I imagine any full service hydraulics store could help you.
/ Grapple Design #137
Very nice, I like the teeth along the front edge. Excellent "action" shots too, thanks. What kind of switch did you go with to work the diverter valve?
/ Grapple Design
mike,
just a single pole double throw switch, there are pics in the thread
/ Grapple Design #139
DTD, looks awesome!!! nice job.
Regarding the quickness of the cylinder.....
My thought is that opening fast isn't a problem, heck, it may be a plus.
What size fittings/hose are you using?
On the closing side of the hydraulic circuit you could try installing a 1/4" fitting by using a reducer. Let's say you are running 1/2" fittings??
Get a 1/2" x 1/4" bushing, and/or 1/2" x 1/4" reducer fitting.
If you really want to dial it in, you could use a needle valve, which would serve as a metering device.
Like this:
Just make sure it is high pressure.
I would think simply connecting a reducing fitting would probably serve your purpose. And would be cheap enough, too.
/ Grapple Design #140
shaley said:
I built this 3rd function switch box from a piece of 1x1 tube for my 3rd function valve. That is just plastic tube plugs at the ends. The switches are water proof and dust proof but only switch about 3A at 12v so I added a relay before the valve.
The valve was from Surplus center.
I like this set up over the rocker because I can use it with gloves on.
Did you fabricate the switch box cover collar or is it available from another source? Nice job!!
2015 FREIGHTLINER CASCADIA 125 6X4 T/A GLIDER SLEEPER TRUCK TRACTOR (A59911)
2015 FREIGHTLINER...
Hardi Pull Type Sprayer (A64047)
Hardi Pull Type...
2003 International 4300 Flatbed Dump 571557 (A62613)
2003 International...
Woods HS106 Ditch Bank Mower (A63116)
Woods HS106 Ditch...
Lull 1044C-54 Telehandler (A64047)
Lull 1044C-54...
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
