Grapple Design
/ Grapple Design
Just so you guys know I wasn't just slacking off
/ Grapple Design
It was very cold. Starting to warm up now though. It was my first time plowing with her. It was fun for alittle while. Still like my plow truck better though. The heat works better. I will be resuming the grapple soon though!!
/ Grapple Design #44
I am sure your bucket is 6' wide and FWIW rule of thumb for mechanisms is 15deg angle when lines are drawn between pivots
sweet tractor
/ Grapple Design
so the 15 degrees is to eliminate the cylinder from sticking or fighting against itself?
/ Grapple Design #46
D T D on pix #2 ,tractors sideways, at the bottom of the f e l . the square tube end looks like it rotated out of it's weld. Am I wrong ?
/ Grapple Design
Tool,
Are you talking about where the FEL mounts to the tractor? Does look strange, huh? When I first bought it, I thought the same. That is the way it sits on it. I even searched the internet for pics of other 1070's to make sure.
DaveD
/ Grapple Design
Ok, started the mock up. I will post the final mock. RDLN made an awesome file of the movement of my grapple. I sent him my drawing file and he is making one with my actual design. I will ask him to post when he is complete.
Thanks RDLN
/ Grapple Design
Well, I made the mock up with some luann plywood I had around. I found a design flaw :(. Better to find it now I guess. It can actually be seen on the final dwg, but I missed it.
http://www.tractorbynet.com/forums/...3d1170972778-grapple-design-grapple-final.pdf
The arm hits the 3" angle support stopping it from closing completely. I will be revising the design of the support bracket. Learned alot building the mock though. I can see it in a different light.
Heres some pics of the process. This web site has added the camera to my list of tools!!! :)
/ Grapple Design #50
I betcha you could get away with just notching the arm where it hits the support bracket. That should not weaken the grapple much at all. If you are concerned about strength at that point you could just weld in a sister brace above the notch.
I'd still suggest widening the grapple to about half the width of your bucket.
/ Grapple Design #51
Yep, theres that and possible issues with the clevis on the cylinder end to the mount interference when full down. Make sure you have the cylinder in hand and recheck b4 cuttin steel.
also I am afraid the your bucket surface where mount is attached is going to flex and maybe bend when you are clamped down on sumpin, might want to stiffen bucket or add low setting relief valve or equivalent (I am not too hip on fluid power).
dave I sent you mpegs, cant attach to post
/ Grapple Design
Yeah, I have made an adjustment to the arm pivot bracket. I will revise my mock up before cutting the steel. Rdln, your mpeg is great!! Thank you so much. That is some kind of program you have!!!
/ Grapple Design #53
learn something new everyday, had to turn on "show animation" in tools-internet options-advanced
/ Grapple Design #54
Very nice, Steve. What are you using for CAD?
John
/ Grapple Design
Nice......I'm glad you were able to share it with everyone. I cut out the new pivots I designed for the mock. I will post new mock pictures soon as its done. Your animation fires me up to get this thing done. Still haven't really thought too much on the hydraulics yet, but I have been reading up on options.
/ Grapple Design #58
thats the way the man wants it. I too have never used one, heck dont even have third function line on loader. Maybe on the next tractor
/ Grapple Design
Rob,
I am workin on it. Work has been crazy lately. It's been cutting into my grapple time :(. Saturday, I will revise my mock up just to be sure it works.
Next step after that will be the scrap yard for metal.
I don't have a tooth bar on my bucket yet! They seem to be very useful though. Someone did mention I should get that first before I build the grapple so the grapple arms don't hit the teeth, but I don't know if I can pass both project costs through the Treasurer :(.
Her birthday is on Sunday, think she may want a nice shiny toothbar?
/ Grapple Design #60
Hahaha,
That is one sure way to get yourself killed!
I think a really good birthday present just for her and some flowers works great. Then AFTER that you can run it by her sort of casually.
Another thing you can do is call Markham and ask what their teeth spacing is on a toothbar that fit's your bucket width. Or better yet, if you build your own, draw it up now with the number of teeth you want and fit your grapple between them. Usually 5, 6 or 7 depending on your bucket width. And adjusting the width of your grapple at this stage is no big deal.
Mine is a 72" wide bucket and has 7 teeth.
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
NO ADDITIONAL ONLINE BUYERS PREMIUM ON BID.FIVESTARAUCTION.COM (A64047)
NO ADDITIONAL...
2004 International 4400 Flatbed-Dump (A62613)
2004 International...
2024 FOREST RIVER 6X10 ENCLOSED TRAILER (A63569)
2024 FOREST RIVER...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
