Grapple #2
/ Grapple #2 #1
davedj1
Jackson, NY
Kubota L2501
Built this for a friend of mine.
This one I built out of 3/8 steel, 6" stroke x 2" bore cylinder
even the tubing is 3/8 wall. It should serve him for many years.
/ Grapple #2 #2
I REALLY like the decorations on the gable end of your building!
/ Grapple #2 #4
I’d recommend putting guards on the hoses on the cylinder and the back frame and changing the pin clips to bolts.
/ Grapple #2
The hose protection is enroute.
You think the pins might fall out? I hadn't really considered bolts there. 1" grade 8?
I'm trying to find some 1" bolts with grease fittings on the ends for the hinge points but I have had no luck finding them. I must be using the wrong search name.
Not sure what you mean by back frame? I like having it open to be able to see through it.
/ Grapple #2 #6
Just putting little bolts through the pins in place of the cotter and linch pins would probably work. I meant putting a guard over the hydraulic hose were it sticks about the back frame.
/ Grapple #2
Gotchya
I have some fire hose on order for hose protection. I hadn't thought about a small bolt in place of the pins but I'll look into it. I can see where they may bet snagged and yanked out of the pin.
/ Grapple #2 #9
Amazing work - I love it, and I'm even partial to that colour. Great job :)
/ Grapple #2
Thank you
What do you have in materials. How many hours labor Looks great
I think about $200 in material including cylinder and hoses , labor wasn't too bad but way more grinding than really needed as I traced a wooden template with the plasma cutter. Of course the material is up now. I now have some CAD drawings so I can have the parts cut on a cnc plasma table which will eliminate a lot of hand work and make it go together much faster. I plan on building them and selling them for sub 35hp tractors. I'll get enough parts cut to build two at a time. Thank you
/ Grapple #2 #11
you need to move far west young man ... Like Washington State :) then I'd have a half a chance of buying one
/ Grapple #2 #13
/ Grapple #2 #14
Thank you
How much do they weigh, and how much for one? I live a couple hours from you in CT and am in the market for a 48" grapple. PM me if you want.
/ Grapple #2
I'm not sure on both accounts with the price of steel right now. I tried to keep it light enough for our smaller tractors. I am in the process of getting parts cut with a cnc plasma table. I will give you a shout once I get prices.
I have used mine extensively and love it, I don't think it weights 200#
/ Grapple #2
When I can get some time I think will try make one of
these as you don't remove your bucket: Single Add-A-Grapple for Sale - Ask Tractor Mike-Ozark, MO
probably cost $500 or less for parts cylinder & valve
less than $300 any ideas?????
willy
I built a similar set up on my last tractor, it puts a tremendous amount of stress on the top of the bucket (bent mine and had to install a heavy angle iron to reinforce it) plus you can't see through the bucket. One thing I also did with it was to add some short forks in the corners of the bucket, that helped a lot. After looking at your pic again, I suppose if you set your relief low it might be OK. Shot around for cylinders, ebay has some decent deals for smaller ones.
/ Grapple #2 #18
/ Grapple #2 #19
You don't attach anything to the center of bucket its
bolted on the top sides of the bucket
willy
3PT / LOADER MOUNT HAY SPEAR (A63291)
3PT / LOADER MOUNT...
SDLE20 Mini Excavator (A64047)
SDLE20 Mini...
JOHN DEERE 7420 TRACTOR (A63291)
JOHN DEERE 7420...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
John Deere XUV825E (A61307)
John Deere XUV825E...
2012 John Deere 328D Compact Wheel Loader Skid Steer (A61572)
2012 John Deere...
