Grapple #2
/ Grapple #2 #1
davedj1
Jackson, NY
Kubota L2501
Built this for a friend of mine.
This one I built out of 3/8 steel, 6" stroke x 2" bore cylinder
even the tubing is 3/8 wall. It should serve him for many years.
/ Grapple #2 #2
I REALLY like the decorations on the gable end of your building!
/ Grapple #2 #4
I’d recommend putting guards on the hoses on the cylinder and the back frame and changing the pin clips to bolts.
/ Grapple #2
The hose protection is enroute.
You think the pins might fall out? I hadn't really considered bolts there. 1" grade 8?
I'm trying to find some 1" bolts with grease fittings on the ends for the hinge points but I have had no luck finding them. I must be using the wrong search name.
Not sure what you mean by back frame? I like having it open to be able to see through it.
/ Grapple #2 #6
Just putting little bolts through the pins in place of the cotter and linch pins would probably work. I meant putting a guard over the hydraulic hose were it sticks about the back frame.
/ Grapple #2
Gotchya
I have some fire hose on order for hose protection. I hadn't thought about a small bolt in place of the pins but I'll look into it. I can see where they may bet snagged and yanked out of the pin.
/ Grapple #2 #9
Amazing work - I love it, and I'm even partial to that colour. Great job :)
/ Grapple #2
Thank you
What do you have in materials. How many hours labor Looks great
I think about $200 in material including cylinder and hoses , labor wasn't too bad but way more grinding than really needed as I traced a wooden template with the plasma cutter. Of course the material is up now. I now have some CAD drawings so I can have the parts cut on a cnc plasma table which will eliminate a lot of hand work and make it go together much faster. I plan on building them and selling them for sub 35hp tractors. I'll get enough parts cut to build two at a time. Thank you
/ Grapple #2 #11
you need to move far west young man ... Like Washington State :) then I'd have a half a chance of buying one
/ Grapple #2 #13
/ Grapple #2 #14
Thank you
How much do they weigh, and how much for one? I live a couple hours from you in CT and am in the market for a 48" grapple. PM me if you want.
/ Grapple #2
I'm not sure on both accounts with the price of steel right now. I tried to keep it light enough for our smaller tractors. I am in the process of getting parts cut with a cnc plasma table. I will give you a shout once I get prices.
I have used mine extensively and love it, I don't think it weights 200#
/ Grapple #2
When I can get some time I think will try make one of
these as you don't remove your bucket: Single Add-A-Grapple for Sale - Ask Tractor Mike-Ozark, MO
probably cost $500 or less for parts cylinder & valve
less than $300 any ideas?????
willy
I built a similar set up on my last tractor, it puts a tremendous amount of stress on the top of the bucket (bent mine and had to install a heavy angle iron to reinforce it) plus you can't see through the bucket. One thing I also did with it was to add some short forks in the corners of the bucket, that helped a lot. After looking at your pic again, I suppose if you set your relief low it might be OK. Shot around for cylinders, ebay has some decent deals for smaller ones.
/ Grapple #2 #18
/ Grapple #2 #19
You don't attach anything to the center of bucket its
bolted on the top sides of the bucket
willy
2024 DOUBLE A TRAILERS 10226T7KGN GOOSENECK TRL (A64280)
2024 DOUBLE A...
Informational Lot - Financing (A63689)
Informational Lot...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
1072 (A64280)
1072 (A64280)
2023 MANITECH MTECH-2.0T TELESCOPIC WHEEL LOADER (A64279)
2023 MANITECH...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
