Grande L30 configuration questions
/ Grande L30 configuration questions #21
I've had the Woods 7500 on a Kubota 2900 and same problem-low ground clearance. I have also used a Woods 9000 on an older 3400-better. I now have a 3830 with the BH90. Extremely easy to attach and take off as the subframe is permanently mounted on the tractor. About 2 minutes to take off and 3 minutes to put on (watch out that you don't pinch the hyd. hoses when putting the backhoe on).
Ag tires are the best traction if you're not on asphalt or concrete and will last a long time. If you are on concrete or asphalt, get the industrials. I have a tractor business, but have use both. The ag tires just don't hold up on man-made surfaces.
Good luck.
/ Grande L30 configuration questions #22
</font><font color="blue" class="small">( If you are on concrete or asphalt, get the industrials. I have a tractor business, but have use both. The ag tires just don't hold up on man-made surfaces. )</font>
I have to respectfully disagree with that statement.
If you drive your unit on man made surfaces, i.e.: asphalt, concrete, brick and leave the unit in FWA, then the tire wear is pronounced, but in 2wd, the R1's will last nearly as long as the R4's. FWA isn't advisable in no slip situatuions anyway.
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
2021 KMC 7406 (A64126)
2018 Jeep Grand Cherokee Trackhawk 4x4 SUV (A64557)
2018 Jeep Grand...
Planter Seed Plates (A65640)
Planter Seed...
Murray Explorer Go Cart (A65640)
Murray Explorer Go...
