Buying Advice Grand L versus M
/ Grand L versus M #21
I don't understand why a question on which Series Kubota to get turns into a John Deere v Kubota and "John Deere is better", but here we are. Hey, lets get into brake location etc.
We have used John Deere for a lot of years and also Kubota since 2003. I don't have a strong preference for twin pedal v rocker, but my wife prefers rocker. No one has ever hit reverse accidentally on the Kubota, but they have on the John Deere; father in law put his in ten foot of water. Again a personal thing.
The two tractors I use the most are a GL5030 and M8540; both are really nice tractors, but the GL is the "easiest". The GL40 Series has the HST+ which increases engine RPM with the HST pedal, stall guard etc.
For the use specified, my choice would be a GL5740, but you really need to read the thread by canoetpr who got the M because of the cost; seems pretty happy with it.
As to the John Deere v Kubota in the 70-95 HP with Hydraulic Shuttle Shift, I could be as happy with one as the other; just go drive both and you will know which is better for you. I would not let the higher cost of the John Deere be the deciding factor if I was convinced it was a better tractor.
Good luck.
I was not trying to say which one is better, I personally have had a better experience with Deere solely because of the dealer network in my area. Never had problems with them. I was not saying that John Deere was better than Kubota in any way. Kubota makes a great tractor. For the limited seat time I had on a friends it was a great machine except for I was jerky on it because of the rocker HST. I was not saying that John Deere was better, just trying to give the OP as many options as possible to determine which suited his needs best.
/ Grand L versus M #22
No, it's available on most of the M series, including the M4700. My son has the L5040 and it is a nice tractor, but won't do what my MX will as far as effective transmission of power to the ground, but we have two different purposes for our tractors. His is mostly mowing and haying, whereas, I use mine for mostly loader work although I do mow, and use it for general farm maintenance. If you go to the Kubota.com site and build an M series you will see that most of the models are available with HST. I had the GST on my L and it was a great little tractor and I used it for 14 years without any issues then sold it for more than half what I paid for it. I am an orange fan for small farm use.
Hate to nitpick but HST is only available in the MX series of M tractors. Once you get into the M's they are gear drive.
/ Grand L versus M #23
If you do allot of loader work, I would look at the L4740HST+(3). I like the auto-throttle option. The rocker is actually a tredle. I do not use it as a rocker, but move my heel and toe to work the forward and reverse sections. You need to test drive both features to see if you like it. Philip.
/ Grand L versus M #24
I was at my Kubota dealer last week looking at RTVs and made the mistake of looking at tractors. I currently own a John Deere 3320 and have been thinking of trading up to a larger tractor with cab. The Kubota salesman showed me a Grand L 5740 - terrific looking machine! If I want a larger tractor with cab I wondered if I should be looking instead at an M series Kubota. I think the M series is more tractor? And if I move up to a tractor over 60 hp I've heard that I might not have to pay Ontario HST (13%).
The Grand L 5740 is the same price as the M series tractor just over 60 hp so I could save over $5000 in tax!
Does anyone know if I don't need to pay tax on the larger tractor. And how do the two machines compare?
to save on the sales tax you need 60 HP at the PTO, not the motor...the M7040 is the smaller Kub that qualifies, quite a step up from your current machine !!
/ Grand L versus M #25
Hi Doug:
I was in a similar place as you a month or so ago. I had almost purchased a JD 4520 first and then started comparing the Kubota GL5740 to the M7040.
Even though I was rather nervous about losing the HST transmission, I took the plunge for the M7040 with the hydraulic shuttle primarily upon the advice of my dealer. Of course I got lots of great advice from others here as well.
First, you do need to step up to the M7040 rather than the M5140 or M6040 in order to qualify for it being a zero rated farm good and not subject to 13% HST. Since it is zero rated, you need no OFA #. The dealer simply does not charge you HST on the sale. With the GL, you can claim the HST back with your HST account if you have a business.
While I might have eventually been able to claim my taxes back once I started slaughtering my first calves next year, I decided that it was a hassle and not getting charged the taxes in the first place was quite a savings. The M7040 was working out to be cheaper than the GL5740 given this.
I'm at ~30 hours now on the M and here is my list of pluses and minuses
- Better value for the $ because of the saved taxes
- Bigger frame tractor, stronger loader. The Canadian M25 loader is made by ALO and better IMHO than the Kubota loaders. It outspecs the Kubota loader on the GL by a fair margin.
- You can get ags on this tractor and they are not thin like the ags on the GL: OTOH Ags on this tractor with it being big, do rip up areas more so than R4s on the GL5740 (does more so than R4s on my old L3400 anyway!)
- I definitely had / have a learning curve moving away from the HST transmission. Getting the tractor to stop at any precise location is harder than with an HST and there are a number of places I used this 'feature' of the HST e.g. putting on attachments (3pt and front), loader work etc. etc. With some experience I believe this is not much of an issue any more. You do learn that you need to actually use the brake to hold the tractor in position instead of it just being a show piece on the tractor as in the case of HST transmissions. I found that I had to re-learn to use the loader and was not able to get a full bucket of anything for the first while. Took several hours of playing in the manure pile and now I am relatively comfortable with the mechanics of it. The HST transmission is just brain dead easy to use for loader work.
- Air ride seat is definitely a plus over the GL. That is available in the JD 4520 but not in the Kubota GL.
- You have to pay for the second remote in Canada on the M. Two remotes are standard on cab tractors in Canada in the GL.
- I can't believe I ever had a tractor smaller than this and was handling round bales with it. I use 4x5 rounds and even with those little rounds, I am plenty happy I went with the biggest tractor I could afford. Yesterday while my wife was cutting off the twine, one of my cows was brushing up against the round I had on and moving it around. Could really feel it in the tractor. Size matters when you are using rounds!
- Euro style QA on the front is both good and bad. I REALLY LIKE the fact that it auto locks in place once you curl back. I still do find it can be a bit tricker to get the attachment on than the SS style. Not 100% sure if this is because the tractor does not have the HST transmission and so I have to use the combination of shuttle lever / clutch and brake to get it to just the right position, or whether the QA system is a bit more finiky to line up. Maybe both. It is rare though that I miss now that I have practiced. I do find that if I miss then it is more of a pain as one of the attachment is hooked on and the other half has not. With the SSQA it is either on or off.
- Not sure about fuel consumption on the M vs GL. Logically the M uses more but man it does go a long way! My last fill up was at 11.2 hours and I am now at ~30 and it is still showing over 1/2.
- I think two extra gears would make the M PERFECT. I tend to operate in low range in 4th. Would love the option of a 5th and 6th in this range. 4th usually works well but I find that my ideal gear is either 4L or 1H and switching ranges isn't ideal :)
- The biggest problem I have with the M is a annoying rattle around the left rear of my cab inside. No clue where it is coming from but given this is a tractor, a rattle isn't much of a worry :).
- Would have been MUCH easier to teach my wife to drive the GL with HST transmission to pick up round bales for feeding. I've been away for about 10 days at a time and this has been a bit of a pain for her. She feeds squares when the cows run out of rounds. I might just buy a couple extra feeders to deal with this.
Overall, I am quite pleased with the M and would buy it over a GL given the extra size. I have more tractor to grow into and really could not justify giving the tax money to the government instead of using it for a bigger machine. The transition from HST to hydraulic shuttle/gear is a bit of a compromise but it is not huge for me.
I was lucky enough to find a dealer who had both and I spent quite a bit of time driving them around his lot.
JD is a really nice machine also and a JD4520 is quite comparable to the GL5740. I would pick the latter - just my preference. Both are very comfortable tractors to operate IMHO. I do have a bias and wasn't comfortable seeing the Made in Mexico sign on the engine of the JD engine and the plastic hood. The bias probably makes zero sense really but thats why it is a bias rather than a logical conclusion :) I have several customers in Japan and take a lot of comfort as I know the quality they expect and produce. Not to suggest that JD products made elsewhere are not going to be at par, it is just my own bias, comfort and experience.
Don't fool yourself though. Both are global companies.
I also found it quite important to find a dealer that actually dealt with farm equipment who understood the tax implications of the GL vs the M wrt. the 60hp zero rated stuff. Some dealers mainly sell to businesses - landscapers and hobbyists like us and so dealing with the M is rare. One I was dealing with did not know that he did not have to charge tax on the M. I was much more comfortable dealing with a dealer that sold in the farming community as he had a mix of users.
/ Grand L versus M #26
Something that I think has been missed here is the self leveling feature on the M loaders plus the cushioned ride option. The self leveling feature is an absolute joy for loader work and a safety feature if loading round bales. It would be enough to make me trade my GL if size was not a factor.:D
/ Grand L versus M #27
The dealers will know this information ...
But I believe when I bought a tractor a few months back that to qualify for the tax savings the tractor must be over 60 hp
/ Grand L versus M #28
/ Grand L versus M #29
Check the Kubota build site, the M 4700 has the HST option as well as some of the others. I don't know if this link will take you directly to the HST option, but it's there.
Kubota Tractor Corporation - Build My Kubota
The M4700 you refer to is the MX4700 and yes the MX has HST as an option. Once you get into the M series they only offer variations of a gear transmissions. Minor point I know but the MX's are a light economy series of the larger M series.
/ Grand L versus M #30
Why would the site and the decals on the tractors list the M4700 HST as such and the MX5100 as such then? I looked at an M4700 HST when I was shopping and bought the MX5100 HST. They have the same engine only the MX5100 is turbocharged. The MX5100 also has some standard features that the M4700 does not. After looking at the site more closely they do list it as an MX4700, therefore, I do stand corrected. However, Kubota does not list it as a series such as the BX V the B series. They are listed as special utility tractors 43-68 HP. This series has 5 tractors. The MX4700. MX5100, M5640SU/M7040SU, & the M7040SUH.
/ Grand L versus M #31
Specifically, to qualify as 'zero rated' equipment it must be 60 hp at the PTO. Here is link to the appropriate CRA document that specifies the details.
/ Grand L versus M #32
I guess not having had one before I didn't get the self leveling feature. I think it would be neat though. My understanding is that on the M25 loader the self leveling feature is mechanical rather than hydraulically operated.
/ Grand L versus M
Wow - some great information in these latest posts! I guess that to qualify for no tax I would have to get the M7040 which has 64 hp at the pto. Thanks for the analysis of getting used to hydraulic shuttle vs HST. I do love the HST on my JD 3320 but suspect I could get used to the shuttle.
Which JD tractor is comparable to the M7040?
/ Grand L versus M #34
It would be like a 5075M, 5083E. What are you planning to do with that much tractor? I know a tax discount is great but holy !#@& that's a lot of tractor! I would be concerned that is too much tractor. An upgrade from a 3320 to something like this is like one of those Smart cars to a Mack or Peterbilt truck. I don't think you need this much tractor but I guess if size isn't an issue than the more tractor the better!
/ Grand L versus M #35
I suspect it is the JD 5075E. The 5085E Limited Utility is the lowest end cab model. I also never got the same level of comfort form the JD dealers around here so YMMV depending on your local dealer. If you price out these I'd like to know how they compare to the Kubota M7040
JD sure does a heck of a job with ergonomics on their tractors.
I checked out the NH 6040 in detail but I was quite happy with Kubota and the dealer.
/ Grand L versus M #36
I have no idea. The only way I have seen them in these parts are as MX 4700:confused:
/ Grand L versus M #37
I went from a similar size tractor to what he has now (Kubota L3400) to a M7040. The M seemed massive initially but I'm quite pleased with the purchase. I find the turning radius etc to be quite good.
Given the lack of price difference between the GL and the M - once you consider the taxes I can only see a couple good reasons for sticking with a GL:
1. You absolutely must have less size to get into a building, work area or to haul
2. You simply cannot do without the precise control a HST transmission offers - and for precise loader work, I don't think you can beat an HST.
As a farm tractor, I think the M wins in my book.
The question you ask is critical though. What is the application?
/ Grand L versus M #38
I think we can all agree that tractor manufacturers need to simplify their systems for their tractors. I like the 2xxx, 3xxx, 4xxx for John Deere CUTs but then I get lost. Kubota, with the BX, B, M, MX. Then all the subforms of each. Then you know what your getting with each model each ___ model comes with HST standard and ___ comes with gear.
That's just me complaining though.:laughing:
/ Grand L versus M #39
Agree here, I drive both regularly, have a HST on my 3120 and a Power Reverser on my 5410. The HST offers more control over the machine but the Power Reverser offers more power in my opinion.
/ Grand L versus M
The question of why I should upgrade is a good one. There are a couple of reasons. I do use the tractor for snow removal and I'm not happy getting covered with snow and frozen on my tractor all winter. For this reason I have been wanting to upgrade to a tractor with a cab. I will also be getting into ploughing, disking and seeding my fields as well as doing backhoe work around the property and I'm concerned that my 3320 might not be up to the task. It's already at the limit of its power for hauling logs out of the bush.
My JD dealer has a 3720 on the lot with cab, but I'm not sure it has enough power? And if I get a GL Kubota I have to pay the extra 13% HST here in Ontario. I really need to check the relative prices of the GL versus the M7040 (the smallest Kubota that would qualify for no tax).
I do agree that I am considering a tractor that is bigger than I need but the price might be right?
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
QA Trencher (A64127)
NEW 2025 Mini Skid Steer Stand On Loader (A62679)
NEW 2025 Mini Skid...
Rut MFG Mini Excavator Brush Cutter (A64126)
Rut MFG Mini...
SKID STEER PLATE GRABBER (A62613)
SKID STEER PLATE...
Bobcat SC72 (A64127)
