Grand L series cruise?
   / Grand L series cruise? #11
I forgot to test the cruise control in my recent ride on an L4740. Is
there a "resume" function? Separate on-off switch, or is that also
handled by the lever?
   / Grand L series cruise? #12
There is no RESUME BUTTON.
All operated by the lever on your left.
   / Grand L series cruise? #13
Correct, it not really cruise control. It stays at whatever setting you choose and is completley manual in operation. Think of it as the foot pedal without auto return to neutral.
   / Grand L series cruise? #14
So, how is it set when you turn the tractor on (and off)? I saw the lever
and the only thing I can think of is you have to move the lever back to
0 to slow down and stop first, then move it up the next time you get up
to the ground speed you want to go. Correct?
Unfortunately, the JD 4720 did not have the CC option on it when I saw it,
so I do not know how that works to compare.
   / Grand L series cruise? #15
If you hit the brake, the cruise control is disabled. To "resume" you move lever back to zero, then back to where you want it.
   / Grand L series cruise? #16
Also, the cruise control is really a transmission setting, not a throttle setting. It works fine, but doesn't control the ground speed up and down hills perfectly.
   / Grand L series cruise? #17
That is pretty much it. Anytime it is interupted you return the lever to zero and reengage the control.
   / Grand L series cruise? #18
Thx for all the helpful responses, guys. It certainly is not obvious
how it works and the dealer rep was no help. You don't get to see an
owner's manual in a test drive.
I doubt the cruise works with the auto h-ds engaged as the range shift would confuse the computer?
John Deere 920 Platform (A50514)
John Deere 920...
Bale Ring (A50515)
Bale Ring (A50515)
UNUSED X-STAR SKID STEER 72" LAND PLANE (A51243)
UNUSED X-STAR SKID...
2019 KOMATSU WA380-8 LOADER (A51242)
2019 KOMATSU...
2019 Dodge Journey Crossroad SUV (A50324)
2019 Dodge Journey...
2019 MDB FM180 FINISHING MOWER (A51243)
2019 MDB FM180...
