Grand L series cruise?
   / Grand L series cruise? #11
I forgot to test the cruise control in my recent ride on an L4740. Is
there a "resume" function? Separate on-off switch, or is that also
handled by the lever?
   / Grand L series cruise? #12
There is no RESUME BUTTON.
All operated by the lever on your left.
   / Grand L series cruise? #13
Correct, it not really cruise control. It stays at whatever setting you choose and is completley manual in operation. Think of it as the foot pedal without auto return to neutral.
   / Grand L series cruise? #14
So, how is it set when you turn the tractor on (and off)? I saw the lever
and the only thing I can think of is you have to move the lever back to
0 to slow down and stop first, then move it up the next time you get up
to the ground speed you want to go. Correct?
Unfortunately, the JD 4720 did not have the CC option on it when I saw it,
so I do not know how that works to compare.
   / Grand L series cruise? #15
If you hit the brake, the cruise control is disabled. To "resume" you move lever back to zero, then back to where you want it.
   / Grand L series cruise? #16
Also, the cruise control is really a transmission setting, not a throttle setting. It works fine, but doesn't control the ground speed up and down hills perfectly.
   / Grand L series cruise? #17
That is pretty much it. Anytime it is interupted you return the lever to zero and reengage the control.
   / Grand L series cruise? #18
Thx for all the helpful responses, guys. It certainly is not obvious
how it works and the dealer rep was no help. You don't get to see an
owner's manual in a test drive.
I doubt the cruise works with the auto h-ds engaged as the range shift would confuse the computer?
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
2017 BAOLI KBG35 STRAIGHT MAST FORKLIFT (A51242)
2017 BAOLI KBG35...
2002 Winston ProSeries 20K Tandem Axle Equipment Trailer (A47384)
2002 Winston...
UNUSED AGT XZ20R EXCAVATOR (A51243)
UNUSED AGT XZ20R...
2015 CIMC 40FT CONTAINER CHASSIS (A52141)
2015 CIMC 40FT...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
