Grading woods trails??
/ Grading woods trails?? #11
Old timers used to use a tire drag. Get 6 tires and bolt 3 of them together in a line. Use U bolts or else big thick washers and 3/8 bolts. Then add 2 more on the next layer, then the last one making a triangle shape. Then bolt on hooks or chain attachment points to the outside edges of the 3wide. That goes to the 3 pt arms. Just drag that around with the single tire farthest from the tractor and on looser soils it will smooth it out pretty well and it's about free to make.
For a couple hundred bucks you can get a chain harrow, also called a chain drag.
jb
/ Grading woods trails?? #12
My tractor is probably smaller than everybody that has posted so far. It is a 29HP and I run a 5' box blade on it. So all of my trails are 10' wide (three passes - side, side, middle). I created them and smoothed them out with the box blade but via the advice of neighbors, I have started using a 6' landscaping rake. The tines are really thick, heat treated but still forgiving enough that while your tractor is bouncing a bit, the rake is cutting smooth. The idea is similar to the drags mentioned above along with the control of a pivoting scraper blade. The landscape rake pivots in the center and the slots allow material to pass through and fill the voids unlike a box blade that tends to collect material.
For the rough work, I use the FEL and box blade, but for the upkeep and smooth work (and it cuts pretty good), I would highly recommend a landscaping rake. My land is priceless because it came with great neighbors.
/ Grading woods trails?? #13
10' wide??? That's not a trail, that's a road. If you are doing it that wide, then try to build in appropriate slopes on curves and crown it in the middle on flat straight stretches.
43023 (A59228)
43023 (A59228)
2017 FORD F-150XL CREW CAB TRUCK (A59823)
2017 FORD F-150XL...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
2860 (A56857)
2860 (A56857)
