grab hooks on equipment for tying it down
   / grab hooks on equipment for tying it down #11
I don't have a grille guard on my T2320 but there are holes to bolt one to it. I drilled two of the holes, one on each side, to fit a clevis like this.
1 1/4 x 3 3/4 Straight Tractor Clevis
You can kind of see them in this picture
   / grab hooks on equipment for tying it down #12
I did the same thing. Works great.
   / grab hooks on equipment for tying it down #13
The frame on my XR3037HC does have holes pre-drilled that I could have bolted the D-rings to. However, where the D-ring would have bolted on the right side the exhaust pipe is right in the way for it to swing up. I didn't want to cut or bend the pipe which is why I mounted them on the brush bar.
   / grab hooks on equipment for tying it down #14
I would stick to a closed hook, D-ring, or chain around a solid portion of the equipment. Anything that has an open end to it such as a plain "hook" may allow the chain to come loose under slack. Such as a sudden back and forth movement or failure of another portion of the tie down system. Just my 2 cents.
   / grab hooks on equipment for tying it down #15
Here is what I did to mine
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51243)
KNOW BEFORE YOU...
Crash Mobile S/A Trailer (A50324)
Crash Mobile S/A...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
DIRTDOG CBX60 5' BOX BLADE (A51243)
DIRTDOG CBX60 5'...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
TAKEUCHI TL12V2 SKID STEER (A51242)
TAKEUCHI TL12V2...
