grab hooks on equipment for tying it down
   / grab hooks on equipment for tying it down #11
I don't have a grille guard on my T2320 but there are holes to bolt one to it. I drilled two of the holes, one on each side, to fit a clevis like this.
1 1/4 x 3 3/4 Straight Tractor Clevis
You can kind of see them in this picture
   / grab hooks on equipment for tying it down #12
I did the same thing. Works great.
   / grab hooks on equipment for tying it down #13
The frame on my XR3037HC does have holes pre-drilled that I could have bolted the D-rings to. However, where the D-ring would have bolted on the right side the exhaust pipe is right in the way for it to swing up. I didn't want to cut or bend the pipe which is why I mounted them on the brush bar.
   / grab hooks on equipment for tying it down #14
I would stick to a closed hook, D-ring, or chain around a solid portion of the equipment. Anything that has an open end to it such as a plain "hook" may allow the chain to come loose under slack. Such as a sudden back and forth movement or failure of another portion of the tie down system. Just my 2 cents.
   / grab hooks on equipment for tying it down #15
Here is what I did to mine
2011 CATERPILLAR 259B3 SKID STEER (A51242)
2011 CATERPILLAR...
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
2008 FORD F-750XL SUPER DUTY ASPHALT DISTRIBUTOR T (A51243)
2008 FORD F-750XL...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
1993 Mono Dump Trailer (A50514)
1993 Mono Dump...
