Governor trouble
   / Governor trouble #1
Jerry B Good
S650g
I recently got a 650g that had been idle for long time. Got it running pretty good but the governor not picking up the load. There's only 129 hours on the hour meter. Seems like low hours to have this problem. Any clue to where I start?
   / Governor trouble #2
Check all the fuel filters and flow TO THE INJECTION PUMP..
I haven’t looked it up at the moment but, the pump requires about 6-8 psi at the pump inlet..
Good luck
   / Governor trouble #3
With that title, I was worried this might be about politics. 😉
   / Governor trouble
Good luck
Are you referring to injection pump for a diesel? This is a gasoline model.
   / Governor trouble #9
I thought you were in California.
