Rotary Cutter Got the Rotary Cutter & Mower!
   / Got the Rotary Cutter & Mower! #1
DaveM
Tioga county, NY
Kubota B2710/LA402 FEL, R4's
Hey Gang- The Bush Hog SQ600 and the Land Pride FDR2560 was delivered on Friday. It's still too soon to use the mower but I finally got to do some real tractor work with the cutter. I'm totally amazed at the ability of the tractor/cutter combo to annihilate about 1.5 acres of brush!! It took about 5 hours as I took it slow and learned it's cababilities while also triming around aprx. 60 spruce trees. I cut lots of huge multi-flora rose bushes (some of these had their own zip codes /w3tcompact/icons/smile.gif) and many wild apple saplings with trunk diameters up to aprx. 1.5". The delivery guy gave me a good tip for cutting the rose bushes. For the really big ones I'd back up to them with the cutter raised and slowly lower it on top. Did I say I was totally amazed?! I did discover a few large stones though and these did not do the blades any favors. Both blades now have some major "ripples" in the cutting edge. I suspect that this season will be toughest on these blades as I cut brush for the first time. Future cuttings will be mostly grasses and thin shoots from the roses and saplings I cut now. If I removed the blades, could I hammer them back, more or less, to their original shape? Should I not worry about it and continue to use them this way for the rest of the season? Maybe get new blades next year and save these blades for future rough stuff?
A related multi-flora rose question too. Am I fooling myself by thinking I can eventually kill these roses if I keep this area cut? Is it worth trying to pull or dig out the roots?
Did I say I was totally amazed?! /w3tcompact/icons/smile.gif
Thanks- Dave
   / Got the Rotary Cutter & Mower! #2
Dave,
No you won't control them just by cutting them. You also will have to spray them as well. You can keep them knocked down but they will spread out over the ground if you don't spray them.
Richard- Thanks for that info. I kinda thought that just cutting them wouldn't really eliminate them. At least by cutting them I can now get to the trunks and roots. Do you or anyone else know the name of the chemical one should use? Could I walk around with a spray bottle of this stuff and just spray the trunks to minimize contact with other plants?
Thanks Again- Dave
   / Got the Rotary Cutter & Mower! #4
Dave,
I use crossbow and it works extremely well!!!! Farm and Fleet has what they call a brush killer that works so so but nothing compared to the crossbow. Yes you can just walk around and spot spray them. Make sure though that you cover the whole plant. With the crossbow and other stuff it's safe to spray on pastures and some other plants. Just read the label to make sure it's safe for where you're spraying it.
Thanks again Richard! I really dislike these things and would like to maintain SOME pasture free of them. I should have asked this at the same time but I'm guessing Crossbow is a brand name? Do you get it only at Ag equipment stores, nursery supply places, garden sections of dept. stores or... just where?
Thanks- Dave
For those of you that were also wondering about this product I finally found some Crossbow, by Dow AgroSciences. It was a bit of a challenge... but not too bad. I first looked in a large hardware/ homecenter type business. Funny how one can go to a place like this and the help you're likely to get is like, "ah yep, this stuff'll kill weeds" as they proceed to read the label in front of you. Fortunately someone here had HEARD of Crossbow and suggested I check with AGWAY. For those of you unfamiliar with AGWAY, they're a do-it-all hardware, garden center, feed store, Ag supply business that is very common in NY and PA. I really like doing business with them. Sure enough, after checking their computer they discovered they had a few gallons in their "chemical room". I was intrigued and a little nervous. A knowledgable guy there pulled out a reference book and confirmed Richard's recommendation. This book gave it an "Excellent" rating for killing multi-flora rose. It also gave "Round Up" by ? an "Excellent" rating but the application requirements were not as flexable as Crossbow. Round Up was MUCH easier to find around here though. Sounds as though the Crossbow will work better when applied to just the stumps of the cut plant. I'll write again someday with a progress report. Oh yeah, cost $58/gal., but 6 oz. in 3 gal. water should do the job and this stuff can be stored and used for a long time.
Dave
   / Got the Rotary Cutter & Mower! #7
Do yourself a favor and save enough for a final spraying in the fall. Give it a final cut to clean the tops and spray when the folage starts to wane, showing you that the sap is running back into the root system. This will insure the best results for killing the root system. Of course, this is totally my own opinion. But it was the only sure way I found to kill blackberry briars and poisen oak.
   / Got the Rotary Cutter & Mower! #8
Scruffy,
How does that work compared to using Roundup in the spring when growth is greatest?
It would be nice to have a spring and fall killing program that work equally well.
Also, how long do you have to wait after using Crossbow to replant?
John Bud
   / Got the Rotary Cutter & Mower! #9
John, what I have done is to make a final cutting right at the end of the season as the plants are starting to go dormant. This gives a fresh cut to make a direct application on the cut.
The action of the sap being drawn back into the root system will draw the chemical into the root system, and ultimately kill the roots. It does not affect the soil, and will allow replanting in the spring. Blackberry briars will actually (in my experience) take a couple of seasons to irradicate, as they are very pervasive critters! The second season is not nearly as bad by any means, but there will be some survivors after the first years run.
When using the roundup in the spring, you are killing the new growth, but leaving the root system intact, and it will sprout again, and again, and again....you get the picture. That is the time the growth is the fastest and heaviest.
Hope my ramblings have been of some help.
   / Got the Rotary Cutter & Mower! #10
The nice thing about crossbow compared to roundup is that you can use it on pasture, or any other grass for that matter, and it doesn't hurt it, so there's no need for replanting in the spring.
   / Got the Rotary Cutter & Mower! #11
Without getting into the organic vs. pesticide debate, be very careful using these sprays. Follow precautions on labels and don't spray on a windy day. Make sure you don't breath the stuff in, or get it on your skin. Also keep pets and livestock out of the area fror a while after spraying, if you can.Many pesticides are organo-phosphates which are nerve toxins, and are carcinogenic. They can do alot of damage to you. All you baby boomers like me will remember all the trouble agent orange caused, which was basically an extremely strong weed killer. I know we're all concerned about tractor safety, please be concerned about pesticide safety, too. This stuff can kill you too, it's just not as fast, but it can be more nasty!
   / Got the Rotary Cutter & Mower! #12
Crossbow is 34.4 % 2,4-D and 16.5% Triclopyr (3,5,6-Trichloro-2-pyridinyloxyacetic acid) plus 49% kerosene (or other inert ingredients) see label and msds
Agent Orange was a 50-50 Mix of 2,4-D and 2,4,5-T (2,4,5-Trichlorophenoxyacetic acid) mixed with inert ingredients including kerosene.
2,4,5-T was removed from the market (if I remember correctly in the early 1970’s). Dioxin in trace amounts was produced along with the 2,4,5-T. Dioxin is not produced with triclopyr, so triclopyr was substituted for the 2,4,5-T in mixtures with 2,4-D. The health effects attributed to Agent Orange have not been see in cases of massive Dioxin exposure, so the connection to the dioxin is weak.
Crossbow is one of the closest pesticides to Agent Orange available today. If you have any doubt about the safety of Agent Orange-like compounds you may want to try Roundup first, if just for the piece of mind.
Roundup is Glyphosate see msds and label .
Glyphosate, 2,4-D and triclopyr all break down quickly in the soil. (These links have Pesticide Information Profiles from the Cooperative Extension Offices of Cornell University, Oregon State University, the University of Idaho, and the University of California at Davis and the Institute for Environmental Toxicology, Michigan State University.)
Both 2,4-D and Triclopyr are chlorinated organophosphates. 2,4-D does have nervous system effects and may have Mutagenic and Carcinogenic properties (studies are in conflict).
Glyphosate is an organophosphate and does not have reported Mutagenic, Carcinogenic, or nervious system effects.
Also see [url]http://infoventures.com/e-hlth/pestcide/pest-fac.html [/url] for pesticide information prepared for the Forest Service. Quotes for Glyphosate and 2,4-D make an interesting comparison:
Glyphosate
<font color=blue>Protective Precautions for Workers: Avoid contact with eyes, skin or clothing. Avoid breathing vapors or spray mist. Wash thoroughly with soap and water after handling.</font color=blue>
2,4-D
<font color=blue>Protective Precautions for Workers: 2,4-D is considered "highly toxic" due to its hazard to the eyes. Workers should wear goggles or a face shield, protective gloves, and protective clothing when handling 2,4-D products. Avoid breathing vapor or spray mist. Use a NIOSH/MSHA approved respirator for protection from pesticide mists. Under emergency conditions, workers should wear a positive-pressure self-contained breathing apparatus. When mixing or loading 2,4-D, workers should wear chemical-resistant gloves. Gloves should be washed with soap and water before removal. Remove contaminated clothing and wash before reuse. Workers should wash thoroughly with soap and water before eating, drinking or using tobacco. Individuals with skin lesions, disease, or sensitivity should avoid contact with 2,4-D. No delay after spray has dried is necessary before workers can reenter the treated area. There is some uncertainty as to 2,4-D's reproductive and developmental effects. As a precaution, therefore, the Forest Service advises that female workers should not be employed in back-pack or hack-and-squirt applications of 2,4-D.</font color=blue>
I use Roundup regularly and would use Crossbow if absolutely necessary but would be extremely careful with it (respirator with an appropriate cartridge, disposable hooded coverall, etc..).
Ed
   / Got the Rotary Cutter & Mower! #13
2-4D is the most common chemical used in the farming industry. Yes you MUST take caution when using any chemical. Roundup, however, will not even come close to knocking out brush like multi-flora, blackberry, etc. At best it just slows them down a little for a week or two.
I just got back from Vegas (boy, that place has changed since my last visit in '79!) and am trying to catch up here.
Many thanks to everyone's contribution on this thread. I for one, will be very careful in my use of ANY pesticides or herbicides.
I just wanted to relay my experience from last Sat. I finally found a good chain with hooks and was really impressed with how easy it was to pull out small tree AND multiflora rose stumps. It's very time consuming and probably won't work for clearing a large area but could prove effective for people that catch these critters early, before they really multiply. Of course, I'm not sure how effective in the long term this will be.
Dave
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
Kubota ZG222 (A60462)
2018 CATERPILLAR 323 EXCAVATOR (A60429)
2018 CATERPILLAR...
2003 PETERBUILT PB330 DUMP TRUCK (A60430)
2003 PETERBUILT...
UNUSED FUTURE 90-PLATE COMPACTOR (A60432)
UNUSED FUTURE...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
