Alan L.
Elite Member
Spent the day picking the Campbell Hausfeld 60 gal compressor at Tractor Supply today. Turns out they didn't have a regulator nor any kind of wiring so I had to go around town picking up everything I needed. Got it unloaded (see pics) and set up, except that I need to figure out where I am going to mount the hose spool, as its in the shop and there are no walls I can screw into and the pearlings are pretty high and not enough vertical surface to mount the bracket.
I wanted to plug in to my 50 amp welder outlet so I went to Lowes, they had a universal plug but no 6/3 wire that I needed. Instead I got a 6' dryer plug with 6/4 wire, cut off the plug and wired to a plug that would plug into the welder outlet. In hindsight, I probably went with too large a wire as it was pretty hard to get it hooked up on the compressor side. But since the breaker is 50 amp I wanted to make sure the wire could handle it.
I had them drain the oil and we laid it on it side for transport, with pallet still attached. It was quite a strain standing it up by myself and I got it unloaded with my forks.
Seems to work great, maybe a little louder than I expected but not near as loud as my old oilless compressor, and won't run near as much anyway. The manual which is completely deficient as to hooking up the wires did at at least recommend Mobil 1 10-W30 oil - 8.5 ounces. Actually I bought a quarter of IR sythetic all temperature oil, which I figure would be about the same. However I was surprised that after the 30 minute break in and a few other cyles today the oil got dark (see pic) so dark it was hard to see the red spot indicator in the glass. Is this normal?
The other concern is that with air cutoff valve, regulator and whatnot there is about 10" or so of "stuff" sticking out the side for the air hose to hook to. Do I really need an air cutoff valve? Not sure what it accomplishess.
The first tank of compressed air had LOTS of water in it. I put a blower on and go most of it out. It was a humid day.
I got the best IR 1/2" impact wrench that Lowe's sells - $179 I think. Its listed at 600 fp. I opened it up and the lack of useful documentation is ridiculous. Virtually no information such as, how much oil to squirt in there before use, what kind of oil etc? I squirted a little 3 in one oil in there and spun it a couple of times - very quiet. There are 4 different powers, but the documentation does not mention the relative power of each setting.
All in all it seems to work great, but I will probably go ahead and put Mobil 1 oil in it at the first oil change. The manual doesn't say when to change the oil the first time, or at least I couldn't find it.
