Got overly enthusiastic and now all my...
   / Got overly enthusiastic and now all my... #1
Beaux Duke
S.E. Louisiana
Kubota L48
Gravel has moved to the edges of my road because of my land plane skills being ineffective.
I tried using the front bucket to pull things back towards the middle so I could spread again using my land plane but that is a huge time waster for me. Back and forth, at an angle trying pull material towards the center. I have got about a half mile of road to deal with.
I was thinking of buying a drag blade but the units at TSC seemed a little light weight. I do not need a big heavy attachment but I do not like the lightweights I have been seeing. I am not sure what would be the best attachment for the job. I had thought the land plane would pull material in for me but I am not having any luck pulling material to the center while traveling in a straight line.
Who has dealt with this problem already?
   / Got overly enthusiastic and now all my... #2
I've carefully watched many landplane videos, looking for ideas for my build. There is little to no gravel movement sideways. The angle is too small. I think I'll make mine with a straight blade.
Anyway, a rear blade or a rake, at about a 45 degree angle, would work to move gravel to the center. Gauge wheels will help. Then use your landplane.
Watch for a used blade or rake. Look in Craigslist in both the "farm+garden" and "heavy equipment." (Some people seem to think that "heavy equipment" means anything they can't lift.)
Bruce
   / Got overly enthusiastic and now all my... #3
I've got a light weight blade that I pull behind my B7200 for cleaning debris off concrete and light grading work. I think a heavier blade would work good for moving gravel back to the center.
   / Got overly enthusiastic and now all my... #4
Yes, either a Landscape Rake or a Rear/Angle Blade. I prefer a Landscape Rake for gravel.
Buy sufficiently wide so the implement covers your tire width WHEN IT IS IN ITS ANGLED OPERATING POSITION. Usually this is about 12" wider than rear tire spread.
In all ground contact work, weight is your friend.
everytfhingattachments.com makes a particularly good Landscape Rake.
LINK: Everything Attachments | Skid Steer Attachments, Tractor Attachments, 3 Point Hitch Attachments, and Farm Tractor Implements.
   / Got overly enthusiastic and now all my... #5
I have a York rake and a medium duty rear blade;the rake will do a better job on uneven ground pulling gravel back on the road way.
   / Got overly enthusiastic and now all my... #6
I tried using the front bucket to pull things back towards the middle so I could spread again using my land plane but that is a huge time waster for me. Back and forth, at an angle trying pull material towards the center. I致e got about a half mile of road to deal with.
I was thinking of buying a drag blade but the units at TSC seemed a little light weight. I don稚 need a big heavy attachment but I don稚 like the lightweights I知 seeing. I知 not sure what would be the best attachment for the job. I had thought the land plane would pull material in for me but I知 not having any luck pulling material to the center while traveling in a straight line.
Whoç—´ dealt with this problem already?
Land planes are for folks who do not want a crown on their driveway.
They like a flat driveway, and their gravel migrates beyond the edge of the traveled surface.
Eventually, they need to order more gravel, and the migration begins anew.
Frequent puddles are also a side benefit from using a land plane (flat).
Tractor Data shows your Kubota width as 74.5".
You would be well served to purchase a 96" rear blade.
Here is what I think is currently the very best deal on a 96" blade.
King Kutter Pro (PRB 96)
$579.99 from Blain's Farm & Fleet - they only have 5 left - apparently they buy lot quantities.
Shipping ( I picked ZIP 70123 -New Orleans area) $140.05
No sales tax!
Total delivered to your door - $720.04
I have 4 King Kutter implements, (60" tiller, 60" box blade, 84" back blade, 60" brush cutter, and am pleased with all of them.
My back blade is 26" wider (13" each side) than my Ford 1920 wheel track, and can be offset another 15" as well. I have significant ditches on both sides of my driveway, so I must keep my wheels away from the driveway edges, or ...over I will go!
I loose NO gravel off the sides of my driveway, by using a 45 degree blade angle,
and .......I love LOTS of crown (never puddles)!
KK paint quality is only fair at best, but KK implements are heavy, and solidly constructed.
The blades sold at TSC are cheaply constructed, (Tarter Gate? or County Line?) and built specifically for TSC pricing.
   / Got overly enthusiastic and now all my... #7
It would depend on your land plane (Brand vs homemade) You can crown a road if you go in the right direction on the correct side of the road. You also need to start on the edges and work towards the center. Commercially sold planes generally have the business blades angled and a flat blade at the rear. You want to pull it with blades angled back toward the center of the drive. Stay off the center until/unless it's needed.
   / Got overly enthusiastic and now all my... #8
I've used my Land Pride LPGS on my mile long gravel driveway for four years now and can truthfully say - it WILL NOT move gravel horizontally. For this task I use either - my Bush Hog roll over box blade(ROBB) or my uber heavy Rhino rear blade.
I SERIOUSLY doubt that your gravel moved to the edges of your driveway because of your use of your LPGS - effectively or ineffectively. Its my humble opinion that your gravel would become sand before you could move it to the edges with the LPGS. Its most likely the gravel moved to the edges simply because of traffic.
Now - after all that hot air & BS passes on - what you need is a rear blade of appropriate weight or a landscape rake. With a little practice you will be able to recover the gravel lost to the edges.
Look for the Implement Limitations page(s) in your owners manual. It will tell you the max weight & width of various implements.
My Imp Lim pages for rear blade - - max weight- 1000# max width- 72". My Rhino rear blade weighs 1000# & is 96" wide. Kubota is very cautious on what they call out for max implement specs. With a 72" rear blade - there is NO WAY I could even begin to cover my rear tire track width when I plow snow. My rear track width is 80". I just barely cover the 80" width when offset and angled to plow snow.
   / Got overly enthusiastic and now all my... #9
An angled rear blade, a yoke rake especially when angled is one of the worst tools to use unless you want to leave your fines behind and windrow stones in your driveway. A rake tends to separate the material and the local gravel that I get if you lose the fines it will not compact or pack in and all you will have is a bunch of marbles to drive on.
   / Got overly enthusiastic and now all my... #10
Guess I did not explain correctly.
Gravel will not move to the side of a driveway from using a land plane.
Gravel will move to the driveway side, because of traffic,.... but the land plane has essentially zero capability to pull it back onto the driveway from the extreme edges.
   / Got overly enthusiastic and now all my... #11
The Harley rake is probably the best tool for moving the material back onto the roadway. It's like an electric planer. One pass is like fifty passes with a stationary tool. But, the Harley tends to leave a slight washboard effect and I'm not sure why.
   / Got overly enthusiastic and now all my... #12
Once I established the crown to the driveway the only think that touches it is the landscape rake.
Dang, I have a rake but I have always called it a root rake. And it has several positions. Looking at the space between the tines I did not think it would be of much use in gravel. I will have to give it a try. How much overlap do you suggest? By that I mean should the end of the rake be even with the edge of the gravel or should I let the end of the rake extend out into the grassy area of the road by a foot or so?
Thanks to everyone for your suggestions and tips!
Repete you would probably think the way we build roads down here is crazy. We typically avoid crowns as it serves as a dam and holds water back instead of letting it drain. My neighbor 2 houses down spent a lot of money building his driveway the correct way. I went and watched for a while. The guy did great work. The road was perfect. 2 big rains later and he has a huge area holding water on one side. I live in a swampy area and the natural drainage can often cause problems.
I have no ditches and when I keep the road flat, water drains and I have no problems. If I let the crown build up, I get wet spots that are quickly widened and deepened by truck traffic.
Depending on the amount of rain I get my drainage will go in 2 different directions. A light rain drains east to west while a really heavy rain channels runoff towards me and goes north south. Fortunately I have no elevation to speak of so I do not have to deal with washed out areas
   / Got overly enthusiastic and now all my... #15
When I built my road it went through a wetland and had to use road fabric due to the mud. I had to use a dozer to cut down about 18" on either side so I could mow it and the grade pretty much follows the crown angle to the ditch. I cover about 2000' of level lowlands and about 1000' climbing up maybe 200' to the house. The delivery folks say I have the nicest 3000' rock driveway in the area. Not a chuckhole in it.
Your house has an elevation of 200 feet?? Must be nice. We’ve had rain the last 3 days so I’m sinking to my ankles when I walk in the yard. I’ve got to drive hours to get to “the high ground”
   / Got overly enthusiastic and now all my... #17
I also use a landscape rake for my 3/8 mile road that goes to my cabin. Works well for me.
   / Got overly enthusiastic and now all my... #18
Top and tilt works very well to crown your road with a box blade or a land plane.
I use both on mine and by simply tilting the blade it pulls gravel into the center of the road. I am surprised nobody mentioned this.
The top link can be angled forward or back to smooth the road as a final step, then a roller if you have access to one.
I use a cheap 6 foot box blade and it does a darn nice job on my drive.
Regards, Fred
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
yellow ball Trailer (A56859)
yellow ball...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
2002 International 9200i Truck (A61306)
2002 International...
KBH Tender (A61307)
KBH Tender (A61307)
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
