Got my new BX2200
/ Got my new BX2200 #1
Anonymous Poster
Epic Contributor
Just goy my BX2200 w/FEL. The next morning after I cut my lawn, I noticed a pool of oil on the floor under the HST by the left rear tire. Looks like it is leaking from a hydraulic fitting. The place I purchased the tractor from picked it up, said they fixed it, and brought it back the same day. Good service, I thought! Well its still leaking, looks like they are going to have to pick it up again. I hope I have better luck in the future with my tractor.
I do have a couple of question on my new tractor though:
1) When the mower (60") is lowered it seems to cut lever, but when raised completely the mower looks quite un-level. Is this common?
2) When cutting my lawn, which was quite long, the mower left an uncut portion of grass near the center of the mower deck. Anyone else experience this?
Dwayne
/ Got my new BX2200 #2
FYI
Rear left side is where the fuel tank commonly leaks.
The mower deck should not skip. Do they have the correct blades on it??? Is the deck square to thwe tractor? If it is on crooked, perhaps its angle of attack is incorrect. To heck wih the dealer for deck setup. Go though the manual. You can handle it. Get it spot on and it will cut superbly.
/ Got my new BX2200
Left side hanging down a little? Mine is off the left stop 1/4" when raised but once lowered it cuts great.
That deck should not leave an uncut strip.
I agree with rogue; better to go through the headache of setting it up yourself. Then you know its right. It takes a little time but its worth it.
Hope you get the leak cured. Surprised that the dealer didn't catch it when he prepped the unit.
BTW, congrats on the new bx /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif!!!
Have fun.
DaveL
/ Got my new BX2200 #4
Behind the left rear tire on the BX2200 is the hydraulic block that the GEL plumbs into. There are three lines, you should be able to see them quite easily. My guess is that they didn't tighten them enough when the dealer installed the FEL or they forgot to put in the o-rings that are under the block. Make them come out and fix it properly and check the deck. Maybe the wrong length blades installed on the deck? (seems like someone else had that happen from the factory). No way it should be leaving a strip of uncut grass, even if the deck wasn't set up properly. Make them fix these issures, and I'll bet you lunch that you're gonna love that machine. I can't believe how much I can do with mine! /forums/images/graemlins/cool.gif
/ Got my new BX2200
</font><font color="blue" class="small">( That deck should not leave an uncut strip. )</font>
Only seems to in deeper grass, I will see when I cut agagin.
</font><font color="blue" class="small">( Behind the left rear tire on the BX2200 is the hydraulic block that the GEL plumbs into. There are three lines, you should be able to see them quite easily. )</font>
Dwayne
Yes, I believe it is one of the lines coming from that block. They claimed it was a bad o-ring. I too am surprised they did not find it before leaving the shop. I am more surprised they didn't get it fixed when they brought it back to the shop.
/ Got my new BX2200 #6
For cutting lawns you need to really keep the rpms up. If I am trying to cut heavy grass I will run the engine at almost 3000 rpms.
2016 Chevrolet Trax AWD SUV (A59231)
2016 Chevrolet...
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
2005 JOHN DEERE 160C LC EXCAVATOR (A59823)
2005 JOHN DEERE...
2000 16ft T/A Utility Trailer (A59231)
2000 16ft T/A...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
(INOP) 2015 POLARIS SPORTSMAN ACE 570 (A59823)
(INOP) 2015...
