Got my bx24 on 7/16/08!!! Questions galore!
   / Got my bx24 on 7/16/08!!! Questions galore! #21
Thanks for all the great information! As a newbie I'll have lots of silly questions.
Here's one:
How should I wash the tractor? Hose? Pressure washer? Air compressor? Sensitive areas to avoid?
Thanks
I just use the hose and soapy water
And don't sparay the dash hard.
If usinging a pressure washer don't hit the greese fittings hard with it .
   / Got my bx24 on 7/16/08!!! Questions galore! #22
Also, some members have reported electrical glitches when getting the instrument panel wet.
I am 1 of those members.
Me too. I had trouble until I drilled a small hole in the bottom of the switch and sprayed some wd in there. I Havent had a problem since. If the flasher switch get water in it it will run your battery down.
   / Got my bx24 on 7/16/08!!! Questions galore! #23
I use a pressure washer, with the lower pressure black tip, to clean off thick mud after a hard day of digging etc but usually only use regular house water pressure to give the BX23 it's semi annual soap & water bath.
I don't wash it after every use, which is mainly finish mowing now, but I do use a high pressure blower to blow it off. This keeps it relatively clean and this also allows for a nice cool down period for the engine and HST as I blow it off with it at low idle. It's always good practice to allow a diesel engine thats been worked fairly hard to cool down with a couple minute idle before shutdown.
Likes been said, avoid applying high pressure water to the dash as the high pressure moisture has a way of making it's way into the bowells of the headlight and emergency light switches. When this happens your BX will start playing the "lights on-lights off" game with you.
Oddly enough, when these very same BX's sit out in all kinds of weather at the various dealerships, they don't play these games :D
Good luck
500 gal Fuel Barrel with Pump (A50515)
500 gal Fuel...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
JOHN DEERE 4440 TRACTOR (A51243)
JOHN DEERE 4440...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51242)
2020 KOMATSU...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
Miller Welder (A51691)
