Got my bx24 on 7/16/08!!! Questions galore!
   / Got my bx24 on 7/16/08!!! Questions galore! #21
Thanks for all the great information! As a newbie I'll have lots of silly questions.
Here's one:
How should I wash the tractor? Hose? Pressure washer? Air compressor? Sensitive areas to avoid?
Thanks
I just use the hose and soapy water
And don't sparay the dash hard.
If usinging a pressure washer don't hit the greese fittings hard with it .
   / Got my bx24 on 7/16/08!!! Questions galore! #22
Also, some members have reported electrical glitches when getting the instrument panel wet.
I am 1 of those members.
Me too. I had trouble until I drilled a small hole in the bottom of the switch and sprayed some wd in there. I Havent had a problem since. If the flasher switch get water in it it will run your battery down.
   / Got my bx24 on 7/16/08!!! Questions galore! #23
I use a pressure washer, with the lower pressure black tip, to clean off thick mud after a hard day of digging etc but usually only use regular house water pressure to give the BX23 it's semi annual soap & water bath.
I don't wash it after every use, which is mainly finish mowing now, but I do use a high pressure blower to blow it off. This keeps it relatively clean and this also allows for a nice cool down period for the engine and HST as I blow it off with it at low idle. It's always good practice to allow a diesel engine thats been worked fairly hard to cool down with a couple minute idle before shutdown.
Likes been said, avoid applying high pressure water to the dash as the high pressure moisture has a way of making it's way into the bowells of the headlight and emergency light switches. When this happens your BX will start playing the "lights on-lights off" game with you.
Oddly enough, when these very same BX's sit out in all kinds of weather at the various dealerships, they don't play these games :D
Good luck
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2013 Ford F-150...
2016 Peterbilt 320 EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
220 bu Gravity Wagon (A50515)
220 bu Gravity...
2021 JOHN DEERE 410E-II 6X6 OFF ROAD DUMP TRUCK (A51242)
2021 JOHN DEERE...
Skid Pro Quick Attach Plow (A50514)
Skid Pro Quick...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
