Got My 4' Rotary!
/ Got My 4' Rotary! #1
JimBinMI
Coldwater, Michigan
2014 Kubota BX25D-1, 2014 Kubota BX1870
Got My 4\' Rotary!
I finally bought my rotary mower for my NH TC18, 18.5 hp and 14 pto hp. I picked it up yesterday afternoon fully assembled, greased, lubed. It's a Woods XT148, 48" Light Duty Rotary, out the door price was $575. It is shear pin protected, and it doesn't have a stump jumper, that's an option, but I don't have any stumps in my field!
Hooked it up and used it for 1 1/2 hours last night and the TC18 handles it effortlessly! I mowed on my field of approximately 5 acres, only mowed about a third of it so far. Field is overgrown grasses, wildflowers, some baby oaks, brush, bushes, hasn't been mowed in a few years, stuff was between 2'-4' tall. Set the tractor at pto speed and took off, did not go full out but at a decent pace and the engine never bogged, only heard the cutter cutting. Did see my temperature gauge creep up a little and stopped, cleaned the radiator screen and the temp went back down right away. At this rate and my field, I believe the TC18 could handle a 5' rotary, but the 4' is recommended by manufacturer. Just takes longer with the 4' and I think I was grinning the whole time! /w3tcompact/icons/smile.gif
Weight of rotary is approx. 385 lbs. and there are 3 points to attach the lift arm pins, the dealer installed them at the center point which so far seems to work well. With the top link adjusted properly for mowing, I can still lift the cutter off the ground. I also have about 190 lbs. of front weights and NO loader. Very happy with this purchase! /w3tcompact/icons/cool.gif
Just thought I'd give a report! /w3tcompact/icons/smile.gif
JimBinMI
We boys and our toys!
/ Got My 4' Rotary! #2
Re: Got My 4\' Rotary!
Now if I could just talk Pop into one. And we are talking the whole rig. I went to help him run a tiller Saturday. Another used gas Sears with a separate engine at the rear for the tiller. He can't even operate the lever to raise or lower the tiller. So here was two guys tilling and when we were done, the job this thing did was terrible. I've turned that much soil with a fork by hand. Not to mention keeping two gas tanks full. This unit he is running makes 5 in 7 years.
Not only is there a dollar or two flying out the window, the wasted energy is adding up too fast. I asked him if he would like to do the same and cut grass for as little fuel you use in the mighty TC18. He is still pondering the answer. I think it is time Pop and I visit the dealer and run that blue hydro. We do have room for two in the barn.
I'll bet that finished cut looked great even thou it is not a finish mower. (i think?) Watch out for bugs in your teeth when smiling that much. /w3tcompact/icons/laugh.gif
"What is a weed? A plant whose virtues have not yet been discovered."
Ralph Waldo Emerson (1803-1882)
/ Got My 4' Rotary! #3
Jim,
If you keep purchasing new attachments than playing with them,than you won't want to return back to work in a couple of weeks./w3tcompact/icons/wink.gif
Glad to hear your have fun this summer./w3tcompact/icons/smile.gif
Stay safe and/w3tcompact/icons/cool.gif
Thomas..NH
/ Got My 4' Rotary! #4
Jim,
I know you have been thinking about this mower for a while, although I have to wonder if your timing is an effort to fight the "back to school blues"? /w3tcompact/icons/smile.gif Keep us up to date on your new toy. I've been looking myself.
/ Got My 4' Rotary! #5
Maybe you could talk Jim into lending his to your pop for a week or two just to try it out./w3tcompact/icons/smile.gif But I don't think we could pry Jim out of the seat right now even if we both tried. So guess your on your own to talk pop into a new one.
Jim good luck with your new mighty mower and may you hit no tires or stumps. /w3tcompact/icons/smile.gif
Gordon
/ Got My 4' Rotary!
Gordon,
Thanks, only little trees with tiny stumps so far! One inch diameter scotch pines cut just about like the heavy grasses. Used it again tonight until dark, had to use the headlights! /w3tcompact/icons/smile.gif
JimBinMI
/ Got My 4' Rotary! #7
There's nothing like bushhogging land for the first time without knowing where the ruts, holes, stumps, etc. are located. :) The safety rules says to walk the land before mowing but I didn't because this pasture hadn't been touched for 13 years by the previous owner. It's full of ants, bumble bees, chiggers, vines, and thorny bushes of all types and descriptions. Can't even see the ground 2 feet in front of you the weeds are so thick and tall. My JD4300 HST with 513 5' hog took it all in stride. Just went VERY slow so I could back out if the front wheels fell into a hole or something. Only got stuck once in a sandy dry creek bed and had to dig out with shovel and the 4WD was a big help. :) Quite an experience....did alot of sweating from fear of the unknown....never knew what was in front of the tractor! Now I know how Dr. Livingston felt the first time he entered the jungle! haha
/ Got My 4' Rotary!
Used it again last night until I needed the headlights! Rained yesterday so stuff was wet but mowed just as well as when dry. Going out right now to try and finish mowing this field for the first time! When I get done, how long do I have to wait to mow again? /w3tcompact/icons/laugh.gif
JimBinMI
/ Got My 4' Rotary! #10
Must be nice. I got home from work today and my son was cutting one field. He finishes, then my wife takes it and goes out to cut the next. Maybe I can get a turn this weekend.
/ Got My 4' Rotary! #11
Weird, PaulB? Possibly. Or lying? Most likely./w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif Not even I am that old, and I know you're a lot younger than I./w3tcompact/icons/smile.gif
How long before you need to mow again, JimBinMI? If it ever gets as dry up there as it is here, a looonnnng time./w3tcompact/icons/frown.gif
Bird
/ Got My 4' Rotary! #12
Paul,
Lets see. Number of hours of enjoyment with Cindy and Heather vs. number of hours of enjoyment on tractor. Long term gratification vs. short term gratification. I think I would make em wait also.
Ches
/ Got My 4' Rotary!
PaulB,
Thanks for the laughs! /w3tcompact/icons/laugh.gif /w3tcompact/icons/laugh.gif /w3tcompact/icons/laugh.gif
I can't say that I agree though...I might be thinking "how long will I have this tractor, I can mow later" and "would they actually wait?". /w3tcompact/icons/smile.gif
I did finish the field tonight, except for getting the edges closer like I want to. I was mowing for at least 45 mins. to an hour with the headlights on, pitch black out by the time I got done. Seems like I just had 80 hrs. on the tractor and I use it a little, got the rotary and wow...95 hours on it now! I need to get an oil filter, oil, and do the rest of the 100 hour maintenance! More fun times! /w3tcompact/icons/cool.gif
JimBinMI
/ Got My 4' Rotary! #14
You could ask if they would like a ride on the tractor /w3tcompact/icons/wink.gif.
/ Got My 4' Rotary! #15
Now Rowski, haven't you read your operators manual? That would be unsafe (not to mention somewhat distracting).
/ Got My 4' Rotary! #16
Paul,
Sorry man. I love my little Kubota but that is a no brainer. On the other hand, the odds of my wife sending that note are about as good as the odds of my B21 having grown into a D9 over night./w3tcompact/icons/smile.gif
/ Got My 4' Rotary! #17
I sure do like my tractor but I'll say this I also know where that kill knob is and if I ever saw a sight like that in a field around where I live---I do believe that knob would be getting pulled out and the tractor engine would be shut down pto still running and all!!!/w3tcompact/icons/smile.gif
But I can relate to what your line of thought is---but not anywhere that extreme thats all. I would have to take the birthday present and then go back to cutting with a really BIG smile on my face!!! We can dream can't we! The only thing that I may see walking out of the woods is a couple of deer or a rabbit so I have no worries there I guess.
Gordon
/ Got My 4' Rotary! #18
Well Mark we have something in common other than an orange tractor. The chances of getting a note like that from my wife are about the same!!!
Gordon
/ Got My 4' Rotary! #19
Jim,
Congtats on the new mower!! I bought the same one for my B2100. I couldn't stop cutting things either. My father lives across the street from me and has a 30+ yr old Cub Cadet riding mower. Nice tractor, but the steering linkage is failing and it is very hard to drive. My dad is 69 and steering for a long time bothers his shoulder. Since I got the mower for my tractor, his 2 acre field is mowed at least once a week!! The bad thing for me is that he is retired and has more time to have fun with my tractor than I do. This fall, after the weeds die, I am going to walk through my property and cut all of the little stumps flush with the ground so that next year, I can use the mower without fear. Good luck with it and have fun.
Mike.
New/Unused ATS Electric Jack (A65583)
New/Unused ATS...
TAYLOR-WAY 200052 - 21' DISC HARROW (A64277)
TAYLOR-WAY 200052...
2025 NEXHAUL N 714TA/DUMP T/A 14FT DUMP TRAILER (A59914)
2025 NEXHAUL N...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
