Got asked to bid a very unusual project
   / Got asked to bid a very unusual project
I always thought the Corps of Engineers managed that stuff. But I guess they’d hire contractors wouldn’t they? Duh.
Can you drag stuff out and untangle it and let it float downstream? Or does it all have to be pulled out of the water?
Can’t be floated as it would obstruct or possibly damage other structures down river.
   / Got asked to bid a very unusual project #12
You are correct. The Conservancy “manages” it and they are the Customer. They are in control of how it is to be done.
Well then you are in the clear. Have fun with it. Looks like it will be interesting.
Maybe outside your expertise but some problems can be solved with the simple application of explosives.
Yeah, no explosives. You can see the picture was taken from inside a glass wall, which is about 50’ high.
No way we can blow things up….
If the explosives go incorrectly, it could damage the center pillar and cause enormous damage.
I remember when I was doing a large ditching job and was bouncing around ideas, one TBN member thought I would have to contact the United States Coast Guard to clear it with them. :ROFLMAO:
   / Got asked to bid a very unusual project #15
If you don’t have to actually remove ALL the debris, a grapple hook on the and of a small cable could be tossed from the bank and then pulled with a winch, truck or ATV to dislodge the debris. Some debris could be retrieved and hauled off. Some would likely float away down stream. If it’s to far to toss the grapple, a small boat could be used to take it there.
Likely to be less costly than renting a crane and an operator.
Nether will be as much fun as the first suggestion.
   / Got asked to bid a very unusual project #16
The logjam is within reach of an excavator boom? How deep is the river around it?
Otherwise I see a person on the pile attaching cables and a whole lot of winching. What harm is it causing - just aesthetics?
   / Got asked to bid a very unusual project #17
We did some confined space training exercises lowering Public Works employees to the bottom of 50' deep sewer manholes to clear debris. See if your local swift water rescue team wants to do some dry suit training in body recovery. They could attach cables to the debris, and you could winch it in, as they look for the "victim". Of course, a sizable donation will help in their decision making.
   / Got asked to bid a very unusual project #18
If the current is strong I'd fear the first bite you take out the pile will send the majority of it down stream. IF you put a cable around it and pull it out into swift water it may pull the tractor off the bank. IDK just a thought.
   / Got asked to bid a very unusual project #19
video of what will happen if left
around here often cleared by helicopter with grapple. Note you need to set up a line of floats at a 45 degree downstream as often after a few logs are cleared the rest WILL float downstream so set your floats at easy to access location on a bend in the river if possible as the logs naturally swing to the outside of the curve
   / Got asked to bid a very unusual project #20
Put in a temporary "floating barrier dam" to prevent dislodged debris from floating down river.
Rent a long arm boom excavator and proceed.
2011 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2011 Freightliner...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
UNVERFERTH 18' FIELD CULTIVATOR (A52708)
UNVERFERTH 18'...
2012 Ford Fusion Sedan (A56859)
2012 Ford Fusion...
New/Unused 14ft Bi Parting Gate (A57454)
New/Unused 14ft Bi...
BUSH HOG 14' ROTARY MOWER (A52708)
BUSH HOG 14'...
