Got asked to bid a very unusual project
   / Got asked to bid a very unusual project #1
Hay Dude
Epic Contributor
A Hay Field along the PA/DE border
Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
So this is a recently abandoned railway in my town. We have hundreds of them here in the rust belt. Unfortunately, with their abandonment comes a lack of maintenance. I would think they would still have to maintain this, but owner tells me they won’t.
So I have been asked to remove this log jamb.
I have my ideas, but thought some backround information would be helpful.
There is no access from the RR bridge. It is closed off and off limits, so debris cannot be removed from there.
On the right side of the picture, the land you see is mush. You cannot realistically get equipment to the edge of the river from there.
On the left side of the picture, there is a “ledge” of ground. You can get a pickup down there, but not much bigger without cutting/building an access path.
My thought was to rent a crane with a clamshell bucket and an operator and have him “grapple” the logs and swing them over into a waiting debris truck. The crane would sit where you see the foot tracks in the foreground.
Water is fairly deep and current fairly strong. The width of the water from the center of the rail bridge center support to the edge of each bank is about 50’ of water.
Thoughts?
   / Got asked to bid a very unusual project #2
I highly doubt that’s a private stream by the size of it. That would put it in conservation control I would think. Interesting job you are looking at though
   / Got asked to bid a very unusual project #4
I always thought the Corps of Engineers managed that stuff. But I guess they’d hire contractors wouldn’t they? Duh.
Can you drag stuff out and untangle it and let it float downstream? Or does it all have to be pulled out of the water?
   / Got asked to bid a very unusual project #5
Maybe outside your expertise but some problems can be solved with the simple application of explosives.
   / Got asked to bid a very unusual project #7
Exactly my thought too, who “owns” it and who has permission to issue permits for the job? Natural Resources office?
   / Got asked to bid a very unusual project #8
If the riverbank will support the crane, your idea seems the simplest.
You are correct. The Conservancy “manages” it and they are the Customer. They are in control of how it is to be done.
   / Got asked to bid a very unusual project #10
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
RoGator RG1100C (A56435)
RoGator RG1100C...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2011 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2011 Kenworth T800...
INTERNATIONAL 5100 END WHEEL GRAIN DRILL (A52708)
INTERNATIONAL 5100...
2016 Hyundai Sonata (A56859)
2016 Hyundai...
