Got a sticking situation....REALLY !!!
/ Got a sticking situation....REALLY !!! #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
I am planning to stick a 14 inch square section of galvanized flashing to part of a brick chimney that is pretty much bare brick and mortar, only the slightest trace of faded paint, and the chimney section has been powerwashed and given ample time to dry. If I am using one 10 ounce tube:
How many of the guys here say the most effective product for the purpose will be ordinary roofing cement, and how many say PL 400 construction adhesive for decks will have a stronger bond?
/ Got a sticking situation....REALLY !!! #3
I would probably use neither. When it's flashing around a chimney, I like to both embed it into the mortar joint and weave it in with the roof shingles. Anytime I need to "attach" it, I like using anchors and stainless steel screws. Maybe what you are doing is OK, but it's hard to say without pictures. Also galvanized can also rust in time.
Bill
/ Got a sticking situation....REALLY !!! #4
I glued my pine baseboards to primed plaster with the Loctite Bird noted. I was impressed with the grab and hold that stuff has. Neither the walls or the boards were perfectly straight. I did apply as much pressure as I could with heavy stuff pushed against it for 24 hours.
It's kind of a unique situation...maybe the pics will help illustrate my query. The section of roof the chimney is near has a layer of premium shingles only 7 years old. There is a primary roof overhead which drips some water onto the lower roof, and that water wicks lengthwise toward the house siding and sheathing, and there is often a strong wind coming from the east that blows the water onto the chimney bricks. Another picture shows the section of heavy duty galvanized metal I have cut and bent to use as flashing after removing part of two shingles and the siding. While I can nail the flanges to the 3/4" plywood sheathing, I want to stick the vertical 14 inch square of galvanized steel to the chimney bricks. The galvanizing is VERY heavy...a section of 40 year old heating return duct. As JD435Bill noted, the preferred method is to embed it in the mortar joint, but I don't really want to chip out 60 year old mortar. One picture shows the chimney area before I wirebrushed and powerwashed the bricks and removed part of the shingles.
/ Got a sticking situation....REALLY !!! #6
You need to get the flashing to go around the corner and up the side of the chimney to get a good seal. Maybe something soldered up out of sheet copper? Also, the flashing going up the roofline seems to be just sitting on top of the shingles. It is providing NO protection of the joint that way.
/ Got a sticking situation....REALLY !!! #7
I dont have pics but just "Re-Roofed" our place. The chimney was one of the areas giving us trouble as the top has all loosened up and was channeling moisture down the flue and out into attic. I dont think the flashing was actually leaking but ended up re-flashing it with the new roof.
I used the "Black Jack" type roofing sealing between the old & new flashing as well as used it to attach to the brick.
I had to chip & re-lay the crown and top 4 rows of brick as the 80 yr old mortar was too bad of shape to leave it long term. I bent the NEW flashing to fit added the sealant and used 2 cheap blue ratch straps to hold it in-place for a week or two while it all set.
DONT use the PL400 or PL200 they are not really weatherproof or UV inhibited & will dry out & crack. Not a lot will stick to Galvanized metal real well but most of the Roofing Cements should work Better than the PLs
Mark
/ Got a sticking situation....REALLY !!! #8
IMHO ... metal and brick have different rates of expansion. Trying to stick one to the other is just asking for trouble. Chimney flashing is even a worse case. The building roof moves in relation to the chimney. It is better to allow the movement with step flashing covered with counter flashing. Cut a groove and bed the counter flashing to the brick.
Thanks to everyone who provided feedback and information...my situation here is really unique and I wanted to get outside information from the experts...learned a lot from everyone....THANKS TO ALL !!!
/ Got a sticking situation....REALLY !!! #10
I would not use galvanized steel, it will rust in time and leave a stain on your shingles. I think aluminum, copper, or lead would be better choices.
Ken
/ Got a sticking situation....REALLY !!! #11
That explanation is very helpful to me. So after I patch leaks around my chimney, the various expansion rates weaken my patch...which is why I continually repatch. So, even if I patch ok, it will only be expected to last for so long.
My last patch job seems to have held for a few years... I used "GreatStuff" expanding foam...from underneath the roof, in the attic... In addition to pitch on the top.
/ Got a sticking situation....REALLY !!! #12
Would it be silly to suggest a tube of super glue ? :confused3:
/ Got a sticking situation....REALLY !!! #13
I think the original idea of setting four anchors and screwing it in place sounds the best, especially if it ever needs to come off without taking the mortar with it.
Also, I think you may just move the problem down a few feet with that flashing, as it really needs to run all the way down to the base of the roof, otherwise you are just moving the water problem onto the seam below it. My hypothesis, at least, from to few roofs I've shingled.
Sent from my SCH-I500 using TractorByNet
/ Got a sticking situation....REALLY !!! #14
How about 3M 5200. Very sticky, flexible , and waterproof.
I would also use something other than galvy. Al, Cu, or Pb as was mentioned in a previous post.
Would a kick out diverter help you any?
FlashingKickoutWaterDiverter2.jpgFlashingKickoutWaterDiverter1.jpg.
Thanks guys...the pics do not show it very well but the side of the chimney is well flashed ABOVE the rain gutter and when I did leak testing using a hose, the only water that entered the house came from BELOW gutter level...meaning the leak was below the gutter. Last night I put that galvanized patch into place and tacked it onto the vertical sheathing after tucking it under the shingles an inch or so, put the hose overhead and not one drop of water entered the house. I am going to use a grinding wheel to cut a groove in the bricks horizontally just below the soffit, then duplicate the galvanized patch using aluminum, then attach that to the chimney using masonry screws and roofing cement in the groove. Danno1, thanks for the idea of the diverter...that would be an easy addition especially now that I have some shingles to replace.
/ Got a sticking situation....REALLY !!! #17
That's the shizzle right there. That caulk is impervious to everyting that matters, or everything I know of. It might not be cheap but I've never had to replace it. It's been on some of my boats for 20 years and still acts like it did the day it cured.
Amazing stuff!
/ Got a sticking situation....REALLY !!! #18
If you can find Solar Seal caulking , comes in different colors . I seen this caulking get on a piece of metal roofing and another piece just lays on top of the first piece over night and it is a bear to ge the two pieces of metal seperated the next day. Cost about $5.50 a tube Lowes around here does not sell go to a siding company. Put it on chimney behind the metal and then to seal any possible places for water to just go in and possible rot out wood in years to come and where you cut your grove. Also like someone else said try and bend the outer corner to go behind the outer piece of metal. . I would put at least one maybe two tapcons in the brick , or if metal is long enough fasten to soffit and down at roof and on right side next to plywood.
Solar Seal...hmmm, never heard of it....is the stuff anything like that product called Kool Seal that is used on RV roofs...a white caulk/sealant?
/ Got a sticking situation....REALLY !!! #20
Actually, you know what else I like to use up on roofs and siding, is Henry 212. It sticks great, stays flexible, takes roof heat, lasts forever, AND is cheaper than 3M 5200. Oh, also readily avail at Lowes/HD.
