Gooseneck Questions
/ Gooseneck Questions #1
tractorski
southern Vermont
Branson 3510
I am looking at a new dodge 3500 club cab with a short box. One of my questions is if a gooseneck can be used with a short bed. My next questions is if when using a gn trailer, I can put the loader bucket on the flat deck that would be over the truck box. this would allow me to get a shorter trailer. Thanks for your help.
/ Gooseneck Questions #2
Yes and yes.
But why would you want a 1 ton truck with a 6' bed?
/ Gooseneck Questions #3
Because driving a long box with a long cab is like driving a limo.
Yes and Yes. But I caution you on the shorter trailer. It may not be long enough to position the tractor to get proper balance between the tongue and axles. IE longer is typically better.
/ Gooseneck Questions #4
I am with you on the short box. The only way I would own another long box would be on a regular cab truck. You can also fit it in your standard garage as you can not with a long box. As for the GN and bucket yes you can do it. The only issue you will have is with a 5th wheel camper or some GB trailers like box trailers. They can get into the back window of the truck in a hurry in a tight turn. For this they make a sliding 5th wheel hitch but nothing for the GN so be careful.
Chris
/ Gooseneck Questions #5
Because driving a long box with a long cab is like driving a limo....
I am with you on the short box. The only way I would own another long box would be on a regular cab truck....
Chris
To each their own, I guess. I would never own another short box; I get way too much use out of an 8' pickup bed. On the other hand, I would be perfectly fine with a 6' flat bed. Go figure.
/ Gooseneck Questions #6
/ Gooseneck Questions #7
You can buy GN trailers with the extended king pin box already on them. Since short box trucks became so popular with the club cabs and 4 doors, the extended pin boxes have become plentiful.
/ Gooseneck Questions #8
Yea, that is a option. The slider hitch for the 5th wheel hitch only is what I was talking about.
Chris
Landhonor TP2-13-08D Skid Steer Mount Tree Puller  (A62679)
Landhonor...
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
Fuel Tank (A64119)
Fuel Tank (A64119)
KingKutter XB (A64126)
Tenant T17 (A64127)
Tenant T17 (A64127)
New/Unused Wolverine 84in Dozer Blade/Snow Pusher (A65583)
New/Unused...
