Gooseneck Hitch
   / Gooseneck Hitch #1
Foothill Rancher
Foothills of Sierra Nevada
Kubota L4400 2 Ford 8n's
I need to install a gooseneck hitch in my new Dodge and thought I would ask all you experts that do alot of hauling what brands you use.
The one in my old truck is a foldover that has two slots with a bar that slides back and forth for the safety chains but I have not seen this style for awhile, it is a slick setup, very easy to hook everything up. It's taken alot of use and seems to be as good as new.
I just found out you can't drill into the new Dodges frames so I'll have to buy a mounting bracket that is drill free.
I've checked a few out on the internet but not sure if I should change from the style I have.
At this time this will be used for cattle trailers that will spend alot of time in some less than smooth conditions.
What have you guys found that works well?
   / Gooseneck Hitch #2
I use a Reese rail system in my dually but just put a B&W turnover in my F250 I like it better than the reese.
   / Gooseneck Hitch #3
I vote for B&W turnover ... I sure like mine!
Leo
   / Gooseneck Hitch #4
B&W, I use mine for my horse trailer, stocktrailer and then with the fifth wheel adapter it is easy to hook up the travel trailer.
Bake
   / Gooseneck Hitch #5
B&W turnover.
I just installed one in my truck. I looked at lots before I settled on this one. I got it off Ebay for several hundred dollars less than any accessory store around here.
   / Gooseneck Hitch #6
B&W all the way. The others just don't match up.
Chris
   / Gooseneck Hitch #7
surely someone has a different opinion. Is this not tractorbynet??:D
   / Gooseneck Hitch #8
I have installed all types of hitches in my boat trailer business and they are the best. Just like Putnum and the Reece 2.5 unit they are just simply the best for heavy towing on 3/4 and 1 ton trucks. You know they are top notch, you just installed one.
Chris
   / Gooseneck Hitch #9
Seems like a lot of folks on this site like the B&W hitch. The big selling point was it only required a 4" hole removed from the bed, and not a large square of sheetmetal to remove. (Found later it also requiered (2) 1/2" holes for the safety chains) Based on that I installed one on my Ford F250 this past summer. Installation wasn't bad and I haven't had a problem. I saved a bunch of $$ over having the dealer install it, though prepare to get some dust in your eye from working underneath the truck rear.
   / Gooseneck Hitch #10
I installed the B&W on my 2003 Dodge five years ago and really like it. The B&W is rated for 30,000 lbs.
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
Volvo ECR235CL (A53317)
Volvo ECR235CL...
2014 FORD F-150 STX EXT CAB TRUCK (A60430)
2014 FORD F-150...
2019 Deere 35G (A53317)
2019 Deere 35G...
11' CONTAINER (A52706)
2015 Peterbilt National NBT40 Crane Truck (A60460)
2015 Peterbilt...
