Goodbye Kubota, hello EarthForce
Status
Not open for further replies.
/ Goodbye Kubota, hello EarthForce
Glennmac - 4 wheels x 4 wheel drive x 4 wheel steering.
You're right - they have an enormous amount of power for their size. There are a couple of cemetaries around the Folcomer dealerships in MD that are switching from full-size TLB's to EarthForce EF-3's and EF-4's.
MarkC
/ Goodbye Kubota, hello EarthForce #262
Re: More EF-5 info, pictures
So it is sort of like loader teeth, but closer together, like a giant comb ripping out your brush?
<font color=green> MossRoad </font color=green>
MossRoad - Exactly!
MarkC
/ Goodbye Kubota, hello EarthForce #264
Gordon,
Go to 1024 x 768 mode and your screen will "fit" and be normal... /w3tcompact/icons/wink.gif
/ Goodbye Kubota, hello EarthForce #265
When I view in flat mode, everything fits at 800 x 600. When I view in threaded mode, it runs out to the right. My guess is someone posted a picture wider than 800x600 in this thread. Am I correct?
/ Goodbye Kubota, hello EarthForce #266
There's only one inline picture and it's 640 x 480.
MossRoad - Here's a picture of the Brush Brute. I haven't unpacked anything from the trailer yet, so we'll have to make do with some lousy pictures for the time being. For size comparison, the chains you see are 3/8" G80, the overall width of the Brush Brute is 58". As I mentioned before, it doesn't have the mounting plate on it yet, either.
MarkC
MossRoad - And here's a lousy picture of the Switch Hitch. It's obviously laying on its back (with the plate the loader attaches to underneath). At the top, you can see the hook that slips under the top link attachment pin on a 3-point implement (but you're looking at it edge-on, unfortunately - I told you it was a lousy picture...). At bottom right and left are the hooks that slip under the side link pins. Above them at the top of the Switch Hitch are the handles that engage and retract the side link locking plates. In the bottom center of the picture, you see the 2" hitch receiver tube.
In the top background, the tan things are 3 quick-attach plates that will be welded onto the Brush Brute, my 6' Agric tiller, and my homemade Soil Pulverizer, which I'll be posting a picture of shortly.
MarkC
Here's a picture of the Ammbusher. The trailer it's sitting on is 78 3/4" between the rails, and that tiny little thing you see on the center front of the cutter in the left side of the picture is a 20-oz. Diet Dr. Pepper bottle lying on its side. (The crate comes off...)
MarkC
An exciting picture of pallet forks...
MarkC
/ Goodbye Kubota, hello EarthForce #271
The Brush Brute pic didn't post, but the rest did. Thanks. The switch hitch looks like something I've seen before, without the receiver tube(freedom hitch, maybe?). Again, thanks for the picks.
This picture shows the 84" grading rake from York. The black thing you see facing you is a removeable end plate for the drop down grading blade. The gauge wheels are adjustable in height by means of the little handle you see sticking out of the top of the wheel support tube. Total weight of the whole assembly is 947 pounds.
Wedged up against the front of the rake is the 30" McMillen tree auger.
MarkC
Ooops. Here's the pic of the Brush Brute...
MarkC
/ Goodbye Kubota, hello EarthForce #274
With all the power of your new Earth Force don't you need a sig that demonstrates at least one of its considerable capabilities? /w3tcompact/icons/wink.gif/w3tcompact/icons/smile.gif
Mike - Cool! /w3tcompact/icons/cool.gif I had no idea you were a graphics artist...
MarkC
/ Goodbye Kubota, hello EarthForce #276
Bird's inclination that there would be a combination of 2 or more factors sounds right. Theoretically there might be another factor involved, traction or the lack of traction on the rear wheels. Obviously the lack of traction would never be an issue with a machine belonging to Mark but it might be fun to think about the physics involved.
What I am picturing is -- if there is enough power and the rear wheels don't turn due to perfect traction, the tractor will turn around the wheels raising the front off the ground. If there is not enough traction then the wheels turn instead of the tractor. For those of us up north we get to experience this during the snow removal season. Using FEL float in snow does not cause the front wheels to come off the ground but rather wheels just spin. Of course like Bird said the physics involved in the angle between the boom and the pivot point on the tractor (influenced by the distance from the ground and the length of the boom) will dramatically affect how much power must be applied before the wheels lift.
Now that I've thought about this "out loud" it seems that the biggest factor involved in Mark's EF wheels not coming off the ground is probably the front end weight (since we already know that traction is not a problem, or won't be as soon as the Michelin's arrive...). Just my two cents ... which ain't nothin' compared to the EF /w3tcompact/icons/smile.gif
DaveV
/ Goodbye Kubota, hello EarthForce #277
WOW! Stay out of that thing's way. Looks like it will do a great job on brush and saplings.
DaveV - Those sound like very good points to me. Obviously, there's no way the EF-5 is getting as much traction from those rear tires as the L4310 was getting with 19.5" wide Michelins when the L4310 was similarly loaded, but the only time the L4310 was similarly loaded was when the Bradco 609 backhoe was attached, which wasn't really very often, especially not when I was primarily doing loader work.
So, from a practical standpoint, since traction is affected mostly by tires and weight (discounting surface variables, of course) I may be getting close to the same amount of traction with the EF-5, on average, since the L4310 rear tire loading wasn't nearly as high when the backhoe wasn't attached, which was most of the time - and the EF-5 always has the backhoe on it. But, there's still no doubt about it: the EF-5 needs Michelin XM27's on it. Better is better, usually.
MarkC
/ Goodbye Kubota, hello EarthForce #279
How much did they get you for the forks?
bgott - $850.
MarkC
Status
2014 John Deere 650K LGP Crawler Tractor Dozer (A61572)
2014 John Deere...
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
SWINGTEC D-88307 COLD FOGGING APPLICATOR (A64276)
SWINGTEC D-88307...
2010 ATLAS COPCO XAS 185 PORTABLE AIR COMPRESSOR (A64279)
2010 ATLAS COPCO...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
6R LAY-BY SPRAYER (A64276)
6R LAY-BY SPRAYER...
