Goodbye Kubota, hello EarthForce
Status
Not open for further replies.
/ Goodbye Kubota, hello EarthForce
Re: More EF-5 info, pictures
John - What!!! You haven't read all my posts!?! You should feel very alone. You've got to be the only TBN member that hasn't... /w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif
Yes, I have answered that question before, but I'm not surprised you missed it. Actually, I think I answered it in the first posts on this topic, in a response to Rat, but basically, what happened was this: About a year ago or so, I saw an EarthForce machine at a dealer in Greensboro, NC. I wasn't too interested at the time, because they didn't have a mechanical PTO. Later, after I became convinced I didn't need a mechanical PTO if I could have hydraulic PTOs, especially at both ends, I decided that the EarthForce deserved a second look. Then, when I got further into it, I became more and more convinced they were the only machines in their class, the most versatile piece of equpment I'd seen, and extremely well suited to my needs. Does that answer your question?
MarkC
Rat - <font color=blue>would enjoy stopping by to try it sometime</font color=blue> Stop by anytime, but since you'll be coming over 4,000 miles, it might be best to give me a little notice, to make sure I'll be here! I wouldn't want you coming all that way and then missing me.
I noticed a strange difference in the way the EF-5 loader works yesterday, as compared to the loader on my L4310. The L4310, when pushing into a pile, had a definite tendency "rear up" with the front wheels unloading to the point that they got no traction whatsoever, if you left the lift control in float position. As I recall, this didn't surprise me, because every other tractor I've ever used did the same thing. However, the EF-5 doesn't seem to have this tendency. I haven't dug a lot of digging with it yet, obviously, but I tried it several times, and it doesn't seem to unload the front tires at all. I'm wondering if it's a difference in the way the loader connects to the tractor, or if it could possibly have something to do with the self-leveling bucket. It could perhaps just be weight, but the EF-5 should have just as low a percentage of weight on the front axle when the bucket isn't providing a load (and it wouldn't be when it's resting on the ground) as the L4310 did, though the EF-5 does weigh more overall, of course. Any ideas, anybody?
MarkC
/ Goodbye Kubota, hello EarthForce #243
<font color=blue>Any ideas, anybody?</font color=blue>
Probably no good ones, but anyway . . .. Just offhand I can only think of 3 things that might affect that. (1) if the pivot point at the back end of the boom where it attaches to the tractor were lower (closer to ground level), (2) if the boom were longer, putting the bucket farther out in front of the pivot point, and (3) if the front end of the tractor were heavier, thereby holding it down better. And I'm not sure how much difference there is in any of these three.
Oops, was kind of overlooking a fourth possibility; that being the diameter of the tires. I believe the diameter of the rear tires is considerably smaller than the Kubota's. I'd be inclined to suspect that it's a combination of 2 or more of these 4 factors.
<P ID="edit"><FONT SIZE=-1>Edited by Bird on 12/25/01 06:41 PM (server time).</FONT></P>
/ Goodbye Kubota, hello EarthForce #244
I don't think it's the self leveling bucket. I have the mechanical self leveling loader on my TN 65 and it rears up when you're trying to push while it's in float.
Bird - Some good ideas, there, I think. Addressing each, in turn:
1) The pivot point is, if anything higher off the ground than it was on the L4310.
2) I haven't checked the actual specs, but I'm prettu sure the boom is about a foot longer.
3) Again, I don't know this for a fact, but I'm pretty sure the front of the EF-5 is quite a bit heavier than the L4310. Since the it weighs almost 10,000 pounds with no loader bucket, and considering the massive loader and frame, it almost has to have more weight on the front end.
4) I hadn't thought about tire diameter at all, but it's an interesting possibility. I wonder how the geometry involved here would affect what I've observed...
I'm still wondering if the self-leveling feature somehow affects this, too, but I don't see how it could.
I suspect, as you said, it's a combination of a longer boom and a heavier front end. At any rate, it's not a bad deal...
MarkC
bgott - Well, that's another vote against the self-levelling bucket theory. I didn't see how it could work that way, anyhow. I think I'll discard that theory and concentrate on the others. Thanks for the info!
MarkC
/ Goodbye Kubota, hello EarthForce #247
Yep, whatever the reasons are, it would be nice to not have the bucket stop and the front wheels raise on the tractor when pushing into a pile of material./w3tcompact/icons/smile.gif
/ Goodbye Kubota, hello EarthForce #248
Thinking out loud...
When pushing in float mode into a pile of whatever, the FEL comes to a stop but the wheels keep trying to push the tractor forward. In essence, the tractor is trying to drive 'through' the FEL frame and up and over the FEL. Since it's trying to drive 'through' the FEL frame, the natural place (only place?) for it to pivot is at the top/bottom of the rear FEL support. Sound logical?
/ Goodbye Kubota, hello EarthForce #249
Interesting. The loader on my 2500b and the new PT425 both ride up when the bucket is in float also. It is probably something to do with the location the lift arms are connected to the unit and the center of force, etc... I'll bet if you push it hard enough, it will ride up in float. It has to, unless there is some mechanism similar to draft control, that senses the arms are changing angle, and applying up force to the loader arms. But this would defeat the purpose of float, wouldn't it?
<font color=green> MossRoad </font color=green>
/ Goodbye Kubota, hello EarthForce #250
Okay, I've got less experience than a lot of you on this thread, but from my own meager advendures I've found that "float" is a good way to position the loader as I start to push into a pile, but once engaged in the material I usually pop it out of float. For one thing, I know I'm going to be ending the push by curling the bucket and raising it slightly. The side effect is that I don't get the "rearing up" phenomemon (which I do if I stay in float). I can generally push into a pile this way until the engine starts to stall or the wheels start to spin. /w3tcompact/icons/crazy.gif
Now, I've never worked on any surface harder than dirt, and I find that "float" is only good for initial positioning, unless I'm back-dragging. Otherwise, depending on bucket angle, it either climbs over or "hogs in" to whatever I'm trying to work on. Is this the way it works for you folks, or am I just too low on the learning curve? /w3tcompact/icons/smile.gif
/ Goodbye Kubota, hello EarthForce #251
Yes. I put the bucket in float and push forward until it just starts to lift the front. I then pull back to lock and proceed forward.
/ Goodbye Kubota, hello EarthForce #252
Yep, that's the way it works for me, too, Harv.
Harv - As MossRoad & Bird have indicated, that's precisely the way I do it, too. I was just messing around with the EF-5, since it was the first time I'd used it, so I wondered if there would be any difference. Turned out there was...
MarkC
MikePA - That makes sense to me. The difference in behavior almost has to be related to the additional weight.
MossRoad - I think such a "sensing" mechanism would defeat the float postion, as you say. I don't think there's anything like that going on with the EF-5. I'll push it a little harder next time and see what it does. As you predicted, I think it'll still ride up, just be less prone to do it. Like you said, what else can it do?
MarkC
/ Goodbye Kubota, hello EarthForce #255
Mark, is this thread wider than your screen? So you have to scroll foward and back to read a simple sentence. It's driving me crazy. Some threads are like that and most are fine. But this is one of the threads thats wider than the screen and in case I didn't tell you before it's driving me crazy.
Gordon
Well, I just got back from the trip to Folcomer's. I brought home a 6' Ammbusher rotary cutter, pallet forks, 7' York Rake/Grader Blade with gauge wheels, a 5' Brush Brute, a 30"/18" tree auger, a 12" post-hole auger, and a Switch Hitch (which allows a skid steer to pick up 3 point hitch implements, and also includes a 2" receiver).
The Brush Brute has to have a quick-attach plate welded onto it before I can use it, so I don't think I'll be able to report on how well it works for a week or so.
The road is in serious need of grading though, so I'll have to break in the York Rake/Grader soon.
MarkC
Gordon - No, it's normal width on my screen. A little longer than normal, but no wider... /w3tcompact/icons/wink.gif
MarkC
/ Goodbye Kubota, hello EarthForce #258
I'd like some pics and info on the switch hitch when you get time. I would like to make something similar for my PT425 so that I could pick up a few 3point implements that I have.
Also, have heard Brush Brute mentioned several times in posts over the last year, but still am not sure what it is(monster brush hog? brush ripper? brush destroyer). Thanks in advance.
/ Goodbye Kubota, hello EarthForce #259
Certainly looks like a very nice machine, Mark. It doesnt appear that large for all the hydraulic power it has. I see in one picture, it is actually raring up off its front wheels. You will have to shift the cup forward.
What is 4x4x4?
MossRoad - I'll try to get some pics of both the Switch Hitch and the Brush Brute for you tomorrow.
The Brush Brute is a device with "fingers" that stick out front as you drive forward. Trees and brush wedge into the fingers and you pull them up with the loader or by driving forward. Instead of mowing them, you pull them up, roots and all, so they don't come back.
MarkC
Status
Caterpillar 446B Backhoe (A66285)
Caterpillar 446B...
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
2002 International 9200i Truck (A61307)
2002 International...
2018 Bobcat MT85 (A64126)
2018 Bobcat MT85...
2016 Ford F-550 Flatbed Truck, VIN # 1FD0W5HT7GEC46417 (A65563)
2016 Ford F-550...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
