Good quality hydro pump advice needed..
   / Good quality hydro pump advice needed.. #1
PapaPerk
USA
Kubota L3830, Ford Golden Jubilee, 1939 Sears Economy, Polaris Ranger 400, Honda Foreman 450 ES, 2004 Dodge Diesel 3500
Hello,
I'm getting ready to repower my old log splitter.
I've decided on a 5 or 5.5 HP Honda engine. I'm not sure about which pump manufacture to buy.
I would like a high quality American made pump and engine to pump mounting bracket. Any advice on what manufacture to use?
Thank you!!
   / Good quality hydro pump advice needed.. #2
Haldex/Barnes, MTE,Concentric are USA made. Most of the alluminum body pumps are imports.
Thanks for the info!!!
Any suggestions on where to get a 5.5 hp Honda on the cheap?
   / Good quality hydro pump advice needed.. #7
   / Good quality hydro pump advice needed.. #8
I think you might find the 5 hp too small for a 11 gpm 2 stage pump. 8 hp would be better suited for it.
The two stage pumps operate faster on the return stroke or no load stroke, but slow down for the power stroke (actual splitting).
Years ago I was doing the same and was buying from Northern Tool- when it was Northern Hydraulic (pre internet days). They had a ton of info- charts etc to figure out requirements.
   / Good quality hydro pump advice needed.. #9
Specs for: 11 GPM 2 STAGE HYD PUMP S21202-5292
Brand new, MTE HYDRAULICS two stage HI/LO pressure hydraulic gear pump. Ideal for applications such as log splitters, presses and other equipment where rapid movement of the cylinder at low pressure is required prior to automatically switching to the high pressure mode to meet load requirements. The change from LO to HI pressure is automatic with the LO stage pressure preset at 700 PSI.
[ Minimum of 5 HP required for gas engine use. ]
So a 5.5 hp Honda should be good right? :confused2:
PAIR OF UNUSED 60" HANG ON FORKS (A54757)
PAIR OF UNUSED 60"...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2017 Ford F-250 Enclosed Service Truck (A53422)
2017 Ford F-250...
2006 FORD F-150 PICKUP (A54313)
2006 FORD F-150...
2014 Ford F-250 Ext. Cab Pickup Truck (A54814)
2014 Ford F-250...
2013 John Deere 450J LT (A47477)
2013 John Deere...
