Good quality hydro pump advice needed..
   / Good quality hydro pump advice needed.. #11
The 5.5 hp will work. I feel this is marginable hp myself and would prefer not to cut it so close on power. Notice 5hp is the minimum. HarborFreight has the 6.5 Predator on sale right now for $99. thier bigger engine is on sale for $299, not sure of the HP. I bought one to use on my tater digger. It cranked out of the box on about the third pull. I think the Predator engine is basicly a Chinese Honda clone. Dont know if you can compare the quality between the two engines, but I havent noticed any reason to regret my purchase.
   / Good quality hydro pump advice needed.. #12
PapaPerk ,
Yes, that is correct.
JJ thanks for the help! One last question.
Do I need special bolts for attaching pump to bracket and bracket to engine? Thank u
   / Good quality hydro pump advice needed.. #14
Yes, I believe they are metric, and you need to find the depth of the threads.
Look at the drawings for that motor, it probably has the bolt size illustrated.
5 - M8 x 1.25 15Deep (S type)
5/16 - 24UNF 15Deep (Q.U.P.T.V. type)
From the motor drawings.
   / Good quality hydro pump advice needed.. #15
So a 5.5 hp Honda should be good right? :confused2:
Yes a 5.5 Honda is actually a little stronger that a comparable gas engine. So if it requires 5 hp gas it will be enough + CJ
2019 KUBOTA SVL75-2 SKID STEER (A52705)
2019 KUBOTA...
2009 Pierce 105ft. Quint Ladder T/A Fire Truck (A55788)
2009 Pierce 105ft...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A54757)
UNUSED LANDHONOR...
2018 CATERPILLAR D6T LGP HIGH TRACK CRAWLER DOZER (A52705)
2018 CATERPILLAR...
2010 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2010 FORD F750 XL...
Leeboy 685 Grader (A47477)
Leeboy 685 Grader...
