Good quality hydro pump advice needed..
/ Good quality hydro pump advice needed.. #1
PapaPerk
USA
Kubota L3830, Ford Golden Jubilee, 1939 Sears Economy, Polaris Ranger 400, Honda Foreman 450 ES, 2004 Dodge Diesel 3500
Hello,
I'm getting ready to repower my old log splitter.
I've decided on a 5 or 5.5 HP Honda engine. I'm not sure about which pump manufacture to buy.
I would like a high quality American made pump and engine to pump mounting bracket. Any advice on what manufacture to use?
Thank you!!
/ Good quality hydro pump advice needed.. #2
Haldex/Barnes, MTE,Concentric are USA made. Most of the alluminum body pumps are imports.
Thanks for the info!!!
Any suggestions on where to get a 5.5 hp Honda on the cheap?
/ Good quality hydro pump advice needed.. #7
/ Good quality hydro pump advice needed.. #8
I think you might find the 5 hp too small for a 11 gpm 2 stage pump. 8 hp would be better suited for it.
The two stage pumps operate faster on the return stroke or no load stroke, but slow down for the power stroke (actual splitting).
Years ago I was doing the same and was buying from Northern Tool- when it was Northern Hydraulic (pre internet days). They had a ton of info- charts etc to figure out requirements.
/ Good quality hydro pump advice needed.. #9
Specs for: 11 GPM 2 STAGE HYD PUMP S21202-5292
Brand new, MTE HYDRAULICS two stage HI/LO pressure hydraulic gear pump. Ideal for applications such as log splitters, presses and other equipment where rapid movement of the cylinder at low pressure is required prior to automatically switching to the high pressure mode to meet load requirements. The change from LO to HI pressure is automatic with the LO stage pressure preset at 700 PSI.
[ Minimum of 5 HP required for gas engine use. ]
So a 5.5 hp Honda should be good right? :confused2:
/ Good quality hydro pump advice needed.. #11
The 5.5 hp will work. I feel this is marginable hp myself and would prefer not to cut it so close on power. Notice 5hp is the minimum. HarborFreight has the 6.5 Predator on sale right now for $99. thier bigger engine is on sale for $299, not sure of the HP. I bought one to use on my tater digger. It cranked out of the box on about the third pull. I think the Predator engine is basicly a Chinese Honda clone. Dont know if you can compare the quality between the two engines, but I havent noticed any reason to regret my purchase.
/ Good quality hydro pump advice needed.. #12
PapaPerk ,
Yes, that is correct.
JJ thanks for the help! One last question.
Do I need special bolts for attaching pump to bracket and bracket to engine? Thank u
/ Good quality hydro pump advice needed.. #14
Yes, I believe they are metric, and you need to find the depth of the threads.
Look at the drawings for that motor, it probably has the bolt size illustrated.
5 - M8 x 1.25 15Deep (S type)
5/16 - 24UNF 15Deep (Q.U.P.T.V. type)
From the motor drawings.
/ Good quality hydro pump advice needed.. #15
Yes a 5.5 Honda is actually a little stronger that a comparable gas engine. So if it requires 5 hp gas it will be enough + CJ
2005 Dodge Ram Crew Cab Pickup Truck (A64556)
2005 Dodge Ram...
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
New/Unused CFG Industrial MX12RX Mini Excavator (A65583)
New/Unused CFG...
(2) Steel Tractor Wheels (A66408)
(2) Steel Tractor...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2017 Ford F-150...
2014 International WorkStar 7500 T/A Leach 2RIII 25Yd Rear Loader Garbage Truck (A64556)
2014 International...
