Good quality hydro pump advice needed..
   / Good quality hydro pump advice needed.. #1
PapaPerk
Veteran Member
USA
Kubota L3830, Ford Golden Jubilee, 1939 Sears Economy, Polaris Ranger 400, Honda Foreman 450 ES, 2004 Dodge Diesel 3500
Hello,
I'm getting ready to repower my old log splitter.
I've decided on a 5 or 5.5 HP Honda engine. I'm not sure about which pump manufacture to buy.
I would like a high quality American made pump and engine to pump mounting bracket. Any advice on what manufacture to use?
Thank you!!
   / Good quality hydro pump advice needed.. #2
Haldex/Barnes, MTE,Concentric are USA made. Most of the alluminum body pumps are imports.
Thanks for the info!!!
Any suggestions on where to get a 5.5 hp Honda on the cheap?
   / Good quality hydro pump advice needed.. #7
   / Good quality hydro pump advice needed.. #8
I think you might find the 5 hp too small for a 11 gpm 2 stage pump. 8 hp would be better suited for it.
The two stage pumps operate faster on the return stroke or no load stroke, but slow down for the power stroke (actual splitting).
Years ago I was doing the same and was buying from Northern Tool- when it was Northern Hydraulic (pre internet days). They had a ton of info- charts etc to figure out requirements.
   / Good quality hydro pump advice needed.. #9
Specs for: 11 GPM 2 STAGE HYD PUMP S21202-5292
Brand new, MTE HYDRAULICS two stage HI/LO pressure hydraulic gear pump. Ideal for applications such as log splitters, presses and other equipment where rapid movement of the cylinder at low pressure is required prior to automatically switching to the high pressure mode to meet load requirements. The change from LO to HI pressure is automatic with the LO stage pressure preset at 700 PSI.
[ Minimum of 5 HP required for gas engine use. ]
So a 5.5 hp Honda should be good right? :confused2:
greenworks (A53421)
greenworks (A53421)
UNUSED RAYTREE RHBC72 - 72" HYD BRUSH CUTTER (A54757)
UNUSED RAYTREE...
30008 (A55758)
30008 (A55758)
TMA (A49461)
TMA (A49461)
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2012 Club Car Carryall 1 Utility Cart (A54811)
2012 Club Car...
