Good price for a welded sub frame ?
   / Good price for a welded sub frame ? #11
You get to decide. If you think all they are doing is burning in the welds you should maybe have at it and see just how little time, skill and tooling it takes. I think it is a fair offer.
I agree... nothing goes as simple as just burning welds. They will likely set up jigs and assure this thing is true. You are paying more than just a monkey that can lay down a nice bead.
   / Good price for a welded sub frame ? #12
Will the steel supplier cut the steel to the exact shape of the template? So would the welder simply assemble and weld? Still seems like a few hours just to weld it. I just welded up a plow frame that I had cut down and moved the ears, and the welding portion took about an hour. I'm a true beginner, but even a professional has to set-up, position the steel, re-position etc.
Also don't forget that this guy has consumables and overhead to pay for. Lets just assume $200, ranging from flap wheel discs to electricity. If he is an independent shop: taxes, insurance, etc.
I think the $800 is pretty good price. But I can understand that $800 is not pocket change. I think your template shows that you have some pretty great fab skills. Why not tackle this yourself?
   / Good price for a welded sub frame ? #13
For all the times some one has asked for just a "little" weld job. Famous last words, "shouldn't take more than twenty minutes" How many of the members here have heard that? Fabbing stuff from scratch is time consuming. The op, having made templates would speed things up for sure, but cutting brackets to spec takes time. Fancy megabucks cnc, trace and cut would be sweet. Been down that quick job path, doesn't usually go as planned.
   / Good price for a welded sub frame ? #14
Agreed. Fast, Cheap or Good. Pick any two.
   / Good price for a welded sub frame ? #15
Compare the rate to your plumber, or electrician, or gas appliance repairman.
Heck, car mechanics get $100 an hour at the dealers (not wages!)
If you feel this job could be done in 5 hours, You are clueless!
O please.
I am not without talent.
Yes, I may have offended some by my cavalier comments on the time of a true professional. By some are passing judgement without knowing anything of me or my background. You sir, are clueless.
This is not my first welding job. Its not a job I am proficient in, but am no slouch.
   / Good price for a welded sub frame ? #17
Any actual doer... should post material cutting, preparing, and lay out (jigging) work. Then some arc work and a presentation of finished product demonstrating it met the need of the requester.
   / Good price for a welded sub frame ? #18
You know, something like that probably won't need really heavy metal. This is 3/8" I did a few years back. But you'd probably be fine with 1/4". Something like that though should cost between 800 to 1200.00 with materials. I know this is a belly pan, but it's not much different, other than I'd reinforce the frame with 2 x3x 3/16" square tubing. That's be enough for this size tractor.
   / Good price for a welded sub frame ? #19
So,
Metal costs
6x6" 3/8 angle 60" $117
3" 3/8 flat stock 14ft $71
6x6" 3/8 flat stock for gusset $50
6x6" 3/8 flat stock for eng mnts /W-Jet $150 = $288
So $500 to burn in the welds ?
Seems high to me.
Going to do this myself. Going to tack it together and then have someone burn it in. Maybe 20 min of someone's time to do it.
Cheap work and cheap customers find each other, happens every day.
   / Good price for a welded sub frame ? #20
Something that has not be mentioned or at least I did not see it is the professional has:
Rent or mortgage on building to pay.
Insurance.
Health benefit for employees.
Cost of welding and other equipment amortized over time.
Consumables.
Utility Bills..
And the cost of education and learning the welding (an other ) skills....
Probably left out a lot but, its hard to make a buck to feed, clothes, house a family, with out all the overhead and you are under cut by someone who does not perceive the value of professional work...
Dale
2008 HONDA GOLDWING GL1800 TOURING MOTORCYCLE (A50505)
2008 HONDA...
1272 (A50490)
1272 (A50490)
2020 John Deere 870GP Articulated Motor Grader (A49461)
2020 John Deere...
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
**SALE ORDER ANNOUNCEMENT** (A51242)
**SALE ORDER...
2017 Ford F-350 Ext. Cab Pickup Truck (A49461)
2017 Ford F-350...
