Good morning!!!!
   / Good morning!!!! #178,531
My back was really hurting today doing the tire changing. got a heating pad on it now. When I opened the back of the subaru to get the last pair of tires out, Snagglepuss had jumped in and went to sleep on a blanket in the back seat. I had the blanket to wrap the costco return tires, to keep the seat clean.
   / Good morning!!!! #178,532
Light rain and 56F. It felt colder this afternoon.
This morning I cut the lawn at the house. I decided to use the bag since the oak leaves don't mulch that well. I should have put the hi lift blades on the EGO but the new mulching blades did ok. I think the EGO likes sharp blades. This afternoon I thought I would get a jump on the grass at the farm which I mowed last Thursday but it needed it again today. Still leaving clipping in the tall places.
The farmers around us are cutting corn. The soybeans at the farm are showing just a touch of yellow.
Yesterday was country fall fest down at the park at the bottom of the hill. I never recognize the names if the performers. I guess they are up and comers. I would have been cold sitting out on the grass but going by the pictures in the paper the fans were enjoying the show. It has gotten expensive. It used to be free but it is $20 now and they charge for parking.
Chris
   / Good morning!!!! #178,533
On mine, the valve is just a bunch of in and out ports, and a motor turns a plate that opens and closes different ports to make up the different cycles.
Right.
There is a gasket in there that seals them all from each other, it wears out and then ports leak across each other.
Ours has multiple seals and spacers in the valve body to isolate the various ports:
And an epoxy-coated brass piston on a rod that the motor actuates to switch from one port to another:
Think that o-ring (above) is what seals the valve to prevent water leakage.
Brine valve assembly:
Usually just a new seal is all that's needed.
(y)
The other major item is to replace the resin beads, but do they really go bad. Really the only reason they go bad is if they aren't getting cleaned in the flush cycle.
Yes ... they can go bad ... depending ...
Chlorine in the water can make them go bad ... although that's not really a problem here for us since our water in un-chlorinated ... unless we shock the well and then don't run it with the softener on bypass to clean the chlorine out of the well before sending it through the softener.
The other thing is iron, which we do have.
Apparently it can build up on the resin beads so that they become less functional over time at removing hardness.
One of the hacks I've read about to handle that is to get some Iron Out and mix it up in some water. Opinions vary as to whether to pour in the brine tank and recharge or pull the valve on the resin tank and dump it directly in, let it sit for 24 hours and then run a recharge.
My manual has a nice breakdown of exactly what each cycle does.
Same here - goes over all the cycles and tells how to set the softener up initially, troubleshooting, etc.
Was able to confirm that what we have is the older 2500 valve, not the 2510.
   / Good morning!!!! #178,534
OK, all you airplane experts (those with the transponder/radar tracking apps). I just took the dog for a walk and saw something which makes me nervous.
Directly above me (Greene, IA 50636), at 8:10 central time: a line of lights (I'm assuming military planes), heading due east, spaced evenly about 2? miles apart, way up in the sky (30k + feet - hard to tell at night). No sound (but they're combines in the area, which would drown it out anyway). The lights disappeared directly overhead, and there were no red/green wing lights, or any under body flashings. I watched about 30 or more bright lights - slowly (speed is hard for me to guess) move west to east and vanish once they were overhead.
What the heck did I just see?
   / Good morning!!!! #178,536
Maybe starlink satellites, there was a launch today.
I'm hoping this is what I witnessed. Scary thoughts - like here comes a war...
Image I just grabbed from the web - yep, looked like these:
   / Good morning!!!! #178,539
Rained early stopped almost done rain came back lasted most of the day quit at sunset temperature’s at 45 heat on in house.
Great explanation rswyan I understood
Prayers for you Ken
   / Good morning!!!! #178,540
45°F and cloudy this morning, got up to 67° today.
Taking a work trip to Minneapolis for an electronics exhibit and conference (SMTA), along with the Production Manager from our other Illinois facility (the guy I replaced at the main facility). Be there tomorrow morning, then flying back Wednesday afternoon. Short trip, but kind of looking forward to seeing what the surface mount equipment industry has to offer these days. Never been to Minnesota either, so I can add another city and state to my list.
Posting via Starlink as well, BEF, and still liking it.
Good evening, gents.
10X12 PUMP (A52472)
10X12 PUMP (A52472)
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A52576)
2019 BIG TEX...
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
378740 (A51572)
378740 (A51572)
2014 KENWORTH T680 (A52472)
2014 KENWORTH T680...
